Ga door naar hoofdinhoud
LG G Watch Spring Bar Pin Replacement
Wat je nodig hebt
  1. LG G Watch Spring Bar Pin Replacement, Wristband: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
    Vraag FixBot
    Voeg opmerking toe
  2. LG G Watch Spring Bar Pin Replacement: stap 2, afbeelding 1 van 2 LG G Watch Spring Bar Pin Replacement: stap 2, afbeelding 2 van 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
    Vraag FixBot
    Voeg opmerking toe
  3. LG G Watch Spring Bar Pin Replacement, Spring Bar Pin: stap 3, afbeelding 1 van 1
    • Slide the spring bar pin out of the wristband.
    • Repeat this step for the other wristband.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Geoff Wacker
92.869 Reputatie
89 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 39
Altijd: 1,343
