Inleiding
Use this guide to replace the stator in your LG front load washing machine.
The stator is part of the direct drive motor. If the motor is broken, it's possible that one or more of the stator coils is burnt out.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Wat je nodig hebt
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use an impact driver to remove the 17 mm nut securing the rotor.
Alternatively, you can use a wrench and a hammer to loosen the nut.
Pull the rotor straight off the stator and drive shaft splines to remove it.
Pull the stator out of its slot on the drum, and flip it so its rear is facing upward.
Use your fingers to unclip the rotor position sensor from the stator.
Pull the sensor away from the stator to completely unclip it.
Remove the rotor position sensor.
You're left with the stator.
Repair didn’t go as planned? Ask our Answers community for help.
5Gids Commentaar
I don’t have comment just question. Does this particular model have a drive belt? Mine is not spinning properly
No it does not. It is a direct drive machine, meaning that the motor drives the wash basket directly. Take a look at this link for some help.
I undertook this repair with the wd14071sd6 model to replace the hall sensor as I was getting the LE error code. I have noted on step 2 that the entire back panel had to be removed to access the rotor. This is very very awkward, as multiple electrics are also connected to the panel via plastic clips.
Despite this, the repair can be achieved without any major electric disconnection work just a matter or having enough space to carefully remove things.
Te alguns estator que não usam o sensor Hall a minha lava seca LG wd17vts6 está máquina tem sensor Hall no estator
Dúvidas, obrigado
A máquina LG wd17vrs6 (modelo) usa sensor Hall no seu estator
Dúvida poderia me informar
Obrigado
