Inleiding
Use this guide to replace the main board in your LG front load washing machine.
This is the main circuit board for the washer. It doesn't contain any buttons or dials—if your washer buttons or dials are broken, you'll need to replace the control panel instead.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Wat je nodig hebt
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Remove the screw(s) securing the top panel brackets to the back panel.
Slide the top panel towards the rear of the device to disconnect its clips.
Unclip the pressure sensor from the chassis or other components.
Disconnect any cables or fasteners secured to the control panel cover.
Repeat this procedure for any bundled cables that keep the cover from opening.
Use a flathead screwdriver or a prying tool, to unclip the main board cover.
Remove the main board cover.
Remove the screw(s) securing the main board to the back side of the washer.
Slide the main board out of its slot in the chassis.
Lift the main board out of the chassis to access each of the connectors.
Disconnect each connector from the main board.
Remove the main board.
Repair didn’t go as planned? Ask our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
