Ga door naar hoofdinhoud
LG Front Load Washing Machine Control Panel Replacement
Wat je nodig hebt
    1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: stap 1, afbeelding 1 van 2 LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: stap 1, afbeelding 2 van 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: stap 2, afbeelding 1 van 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: stap 2, afbeelding 2 van 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: stap 2, afbeelding 3 van 3
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: stap 3, afbeelding 1 van 2 LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: stap 3, afbeelding 2 van 2
      • Slide the top panel towards the rear of the device to disconnect its clips.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Front Load Washing Machine Control Panel Replacement: stap 4, afbeelding 1 van 2 LG Front Load Washing Machine Control Panel Replacement: stap 4, afbeelding 2 van 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: stap 5, afbeelding 1 van 2 LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: stap 5, afbeelding 2 van 2
      • Pull the detergent drawer away from the chassis as far as it will go.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Control Panel Replacement: stap 6, afbeelding 1 van 3 LG Front Load Washing Machine Control Panel Replacement: stap 6, afbeelding 2 van 3 LG Front Load Washing Machine Control Panel Replacement: stap 6, afbeelding 3 van 3
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: stap 7, afbeelding 1 van 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: stap 7, afbeelding 2 van 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: stap 7, afbeelding 3 van 3
      • Disconnect the connectors attached to the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: stap 8, afbeelding 1 van 2 LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: stap 8, afbeelding 2 van 2
      • Remove the screw(s) securing the control panel.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Front Load Washing Machine Control Panel Replacement, Unfasten the detergent dispenser: stap 9, afbeelding 1 van 1
      • Remove the screw(s) securing the detergent dispenser.
      Vraag FixBot
      Voeg opmerking toe
    4. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: stap 10, afbeelding 1 van 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: stap 10, afbeelding 2 van 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: stap 10, afbeelding 3 van 3
      • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
      Vraag FixBot
      Voeg opmerking toe
    5. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: stap 11, afbeelding 1 van 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: stap 11, afbeelding 2 van 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: stap 11, afbeelding 3 van 3
      • Remove the control panel, making sure to thread any cables through the chassis.
      Vraag FixBot
      Voeg opmerking toe
    6. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel board: stap 12, afbeelding 1 van 1
      • Flip the control panel over.
      • Remove the screw(s) securing the control panel board.
      Vraag FixBot
      Voeg opmerking toe
    7. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: stap 13, afbeelding 1 van 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: stap 13, afbeelding 2 van 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: stap 13, afbeelding 3 van 3
      • Pull the control panel board out of its slot and remove it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
4 andere personen hebben deze handleiding voltooid.
Bill Gilbert
40.168 Reputatie
261 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
39.488 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 245
Altijd: 5,581
