Ga door naar hoofdinhoud
Kindle Voyage Battery Replacement
Sean Yap
Sean Yap en 6 andere bijdragers
Voor het laatst geüpdatet op August 2, 2024
2 minuten
Eenvoudig
The battery, like most batteries, gives juice to the device. This guide will show you how to carefully remove it for troubleshooting purposes.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Kindle Voyage Battery Replacement, Back Panel: stap 1, afbeelding 1 van 2 Kindle Voyage Battery Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Battery Replacement: stap 2, afbeelding 1 van 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Battery Replacement: stap 3, afbeelding 1 van 3 Kindle Voyage Battery Replacement: stap 3, afbeelding 2 van 3 Kindle Voyage Battery Replacement: stap 3, afbeelding 3 van 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Battery Replacement: stap 4, afbeelding 1 van 2 Kindle Voyage Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Battery Replacement, Battery: stap 5, afbeelding 1 van 2 Kindle Voyage Battery Replacement, Battery: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • Use a plastic card to pry the battery away from the device.
    • Gently un-clip the battery plug from the device and remove the battery.
Conclusie
37 andere personen hebben deze handleiding voltooid.
Sean Yap
1.461 Reputatie
6 handleidingen geschreven
Cal Poly, Team 19-12, Maness Winter 2015 Lid van Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Leden
10 handleidingen geschreven
18 opmerkingen
Where can I buy a replacement buttery for my kindle voyage?
hegi88 - Antwoord
Where to find a replacement battery for kindle voyage 3G please if any one knows
Himadri Endow - Antwoord
Bump. Cannot seem to procure a new battery for the Kindle Voyage. Nice to know how to replace the old one; just need something to replace it WITH! Thanks for any hints on finding one. Battery model number is: MC-305070, 3.8V 1320mAh/5.01Wh, P/N 58-000056
larryg - Antwoord
Any advance on where one can find a replacement battery for the Kindle Journal?
Charles WRIGHT - Antwoord
Still looking for a source for this battery.
Neil Hall - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 83
Afgelopen 30 dagen: 351
Altijd: 31,861
