Ga door naar hoofdinhoud
Kindle Touch 3G Card Housing Replacement
Adam Yerly
Adam Yerly en 3 andere bijdragers
Voor het laatst geüpdatet op December 29, 2015
5 minuten
Eenvoudig
Next to the battery is the 3G unit. However, in the
models that are WiFi only, there will instead be a plastic placeholder instead. The replacement instructions for both are identical.
Wat je nodig hebt
Gereedschap
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Toon meer…
Video overzicht
  1. Kindle Touch 3G Card Housing Replacement, Back Cover: stap 1, afbeelding 1 van 3 Kindle Touch 3G Card Housing Replacement, Back Cover: stap 1, afbeelding 2 van 3 Kindle Touch 3G Card Housing Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
  2. Kindle Touch 3G Card Housing Replacement: stap 2, afbeelding 1 van 2 Kindle Touch 3G Card Housing Replacement: stap 2, afbeelding 2 van 2
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
  3. Kindle Touch 3G Card Housing Replacement, Battery: stap 3, afbeelding 1 van 3 Kindle Touch 3G Card Housing Replacement, Battery: stap 3, afbeelding 2 van 3 Kindle Touch 3G Card Housing Replacement, Battery: stap 3, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch 3G Card Housing Replacement: stap 4, afbeelding 1 van 3 Kindle Touch 3G Card Housing Replacement: stap 4, afbeelding 2 van 3 Kindle Touch 3G Card Housing Replacement: stap 4, afbeelding 3 van 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: stap 5, afbeelding 1 van 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: stap 5, afbeelding 2 van 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: stap 5, afbeelding 3 van 3
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
    • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Adam Yerly
1.982 Reputatie
7 handleidingen geschreven
USF Tampa, Team 19-5, Blackwell Winter 2015 Lid van USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Leden
8 handleidingen geschreven
2 opmerkingen
Hey, thanks for your guide!
I, however, have one question, maybe I misunderstood - is it possible to add a 3G module to a kindle touch that didn't have one installed by default?
Would it work?
Curious_Guy_Threepwood - Antwoord
You would need to add more than just a 3G module - there’s a slot for a SIM-card tray and special Amazon SIM that are missing from non-3G Kindle Touches. I don’t know if there would be any software changes that would need making.
Darren John de Lima -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 23
Altijd: 2,286
