Ga door naar hoofdinhoud
Kindle 2 Battery Replacement
Wat je nodig hebt
    1. Kindle 2 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Kindle 2 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Kindle 2 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
      • Lay the Kindle face down on a soft cloth to protect its screen.
      • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
      • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
      • Slide the gray plastic top piece away from the Kindle's metal casing.
      • Once the gray plastic top piece is detached from the metal back cover, remove it.
      Vraag FixBot
      Voeg opmerking toe
    2. Kindle 2 Battery Replacement: stap 2, afbeelding 1 van 2 Kindle 2 Battery Replacement: stap 2, afbeelding 2 van 2
      • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
      Vraag FixBot
      Voeg opmerking toe
    3. Kindle 2 Battery Replacement: stap 3, afbeelding 1 van 2 Kindle 2 Battery Replacement: stap 3, afbeelding 2 van 2
      • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
      • Remove the metal casing.
      • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
      Vraag FixBot
      Voeg opmerking toe
    4. Kindle 2 Battery Replacement: stap 4, afbeelding 1 van 1
      • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
      • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
      Vraag FixBot
      Voeg opmerking toe
    5. Kindle 2 Battery Replacement: stap 5, afbeelding 1 van 2 Kindle 2 Battery Replacement: stap 5, afbeelding 2 van 2
      • Pry upward under the black tab with the spudger to dislodge the battery.
      • Use your fingers to lift the battery out of the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
42 andere personen hebben deze handleiding voltooid.
Dayna Scott
985 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-32, Amido Spring 2013 Lid van Cal Poly, Team 12-32, Amido Spring 2013
CPSU-AMIDO-S13S12G32
4 Leden
49 handleidingen geschreven
9Gids Commentaar
I followed this guide, without changes, and was able to successfully swap a battery on a Kindle DX. The DX is essentially a Kindle 2 with a larger screen.
Eric - Antwoord Deel
Thanks, easy and went well!
Maybe you need a thinner spudger, TH?
Laz - Antwoord Deel
Easy! Worked well with the tools described. Kudos for making this available, it gave my old Kindle a new breath of life!
stevenwaegenaer - Antwoord Deel
Easiest replacement I've done. Thanks!
shockwav - Antwoord Deel
An ebay-acquired battery fit perfectly, but failed to reboot the kindle or accept a charge.
the battery looks idential to the Kindale battery to an old analog voltmeter.
I conformed that the kindle terminals were receiving battery voltage.
The replacement guide was just fine, Back to the original battery, which is well past its best-by date!
Charles Kennedy - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 187
Altijd: 41,917
