Ga door naar hoofdinhoud
Keurig K10 MINI PLUS Brew Button Replacement
Matt Bav
Matt Bav en 3 andere bijdragers
Voor het laatst geüpdatet op December 19, 2018
20 - 30 minuten
Moeilijk
This is a lengthy replacement that requires being able to comfortably work around wires, but not necessarily to replace them. This guide is for someone with moderate experience in repairs.
Wat je nodig hebt
Gereedschap
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Keurig K10 MINI PLUS Brew Button Replacement, Cold Water Reserve Lid: stap 1, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement, Cold Water Reserve Lid: stap 1, afbeelding 2 van 2
    • Lift the cold water reserve lid up to reveal its hinge.
    • Using either the metal spudger or the opening tool, gently pry the plastic out of the metal axle.
  2. Keurig K10 MINI PLUS Brew Button Replacement: stap 2, afbeelding 1 van 1
    • Repeat the last step on the other hinge, making sure to keep a firm grasp on the lid as it comes off to avoid dropping it.
  3. Keurig K10 MINI PLUS Brew Button Replacement, Top Needle: stap 3, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement, Top Needle: stap 3, afbeelding 2 van 2
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  4. Keurig K10 MINI PLUS Brew Button Replacement: stap 4, afbeelding 1 van 3 Keurig K10 MINI PLUS Brew Button Replacement: stap 4, afbeelding 2 van 3 Keurig K10 MINI PLUS Brew Button Replacement: stap 4, afbeelding 3 van 3
    • Once you remove the screws, the top cover should come out.
    • The back of the cover is held in place by two locking tabs. To remove the cover, pull it back slightly and it should come free.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  5. Keurig K10 MINI PLUS Brew Button Replacement: stap 5, afbeelding 1 van 1
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
  6. Keurig K10 MINI PLUS Brew Button Replacement, Cold Water Reserve Arm: stap 6, afbeelding 1 van 3 Keurig K10 MINI PLUS Brew Button Replacement, Cold Water Reserve Arm: stap 6, afbeelding 2 van 3 Keurig K10 MINI PLUS Brew Button Replacement, Cold Water Reserve Arm: stap 6, afbeelding 3 van 3
    • Remove two 14 mm Phillips #2 screws.
    • Remove two 12 mm Phillips #2 screws.
    • Lift the arm off the assembly. This will reveal the tank hole as shown.
    • It is recommended that you clog the tank hole with a napkin or something similar in order to prevent small parts from falling into the heating element.
  7. Keurig K10 MINI PLUS Brew Button Replacement: stap 7, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement: stap 7, afbeelding 2 van 2
    • Remove two 9.7 mm Phillips #2 screws.
    • Remove two 11.5 mm Phillips #2 screws.
    • Remove the cold water reserve arm's plug from the arm itself in order to allow access to the base screws.
  8. Keurig K10 MINI PLUS Brew Button Replacement: stap 8, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement: stap 8, afbeelding 2 van 2
    • Remove two 18 mm Phillips #2 screws.
    • Finally, detach the arm from the cold water reserve basin.
  9. Keurig K10 MINI PLUS Brew Button Replacement, Dispenser Head: stap 9, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement, Dispenser Head: stap 9, afbeelding 2 van 2
    • Pull the head assembly forward to reveal the two plastic axle points that keep the head assembly attached to the base.
    • There is a spring concealed by a white piece as shown.
  10. Keurig K10 MINI PLUS Brew Button Replacement: stap 10, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement: stap 10, afbeelding 2 van 2
    • Using the iFixit Opening Tool, gently pry apart the plastic head assembly piece from both the body's axles and its left to remove it.
  11. Keurig K10 MINI PLUS Brew Button Replacement, Brew Button: stap 11, afbeelding 1 van 3 Keurig K10 MINI PLUS Brew Button Replacement, Brew Button: stap 11, afbeelding 2 van 3 Keurig K10 MINI PLUS Brew Button Replacement, Brew Button: stap 11, afbeelding 3 van 3
    • Screws circled in red may be hard to reach and will require a screw driver with a neck width of 5mm or less.
  12. Keurig K10 MINI PLUS Brew Button Replacement: stap 12, afbeelding 1 van 3 Keurig K10 MINI PLUS Brew Button Replacement: stap 12, afbeelding 2 van 3 Keurig K10 MINI PLUS Brew Button Replacement: stap 12, afbeelding 3 van 3
    • Detach the seat by giving it a firm tug up.
  13. Keurig K10 MINI PLUS Brew Button Replacement: stap 13, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement: stap 13, afbeelding 2 van 2
    • Flip over the device.
    • Remove four 11.5 mm Phillips #2 screws.
  14. Keurig K10 MINI PLUS Brew Button Replacement: stap 14, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement: stap 14, afbeelding 2 van 2
    • Reposition the metal lid while keeping the heat sink attached in order to reach the screws underneath.
    • It is recommended that you leave the heat sink aside as it contains thermal paste.
  15. Keurig K10 MINI PLUS Brew Button Replacement: stap 15, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement: stap 15, afbeelding 2 van 2
    • Be careful not to confuse these two screws for the ones behind them.
  16. Keurig K10 MINI PLUS Brew Button Replacement: stap 16, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement: stap 16, afbeelding 2 van 2
    • Turn the device right side up again.
  17. Keurig K10 MINI PLUS Brew Button Replacement: stap 17, afbeelding 1 van 3 Keurig K10 MINI PLUS Brew Button Replacement: stap 17, afbeelding 2 van 3 Keurig K10 MINI PLUS Brew Button Replacement: stap 17, afbeelding 3 van 3
    • Begin to pry open the front plate using the iFixit Opening Tool as shown.
    • Pry upwards in order to take the cover off.
  18. Keurig K10 MINI PLUS Brew Button Replacement: stap 18, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement: stap 18, afbeelding 2 van 2
    • Remove the front plate.
    • Be careful of the wires here.
  19. Keurig K10 MINI PLUS Brew Button Replacement: stap 19, afbeelding 1 van 2 Keurig K10 MINI PLUS Brew Button Replacement: stap 19, afbeelding 2 van 2
    • Remove one 9.7 mm Phillips #2 screws.
  20. Keurig K10 MINI PLUS Brew Button Replacement: stap 20, afbeelding 1 van 3 Keurig K10 MINI PLUS Brew Button Replacement: stap 20, afbeelding 2 van 3 Keurig K10 MINI PLUS Brew Button Replacement: stap 20, afbeelding 3 van 3
    • Remove the button housing to access the buttons.
    • The brew buttons can be easily popped out of place by pushing inwards from the front of the unit.
Conclusie
Matt Bav
612 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S5-G7, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G7, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G7
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 1,357
