Ga door naar hoofdinhoud
JBL Flip 6 Battery Replacement
Wat je nodig hebt
  1. JBL Flip 6 Battery Replacement, Pry up the fabric cover: stap 1, afbeelding 1 van 3 JBL Flip 6 Battery Replacement, Pry up the fabric cover: stap 1, afbeelding 2 van 3 JBL Flip 6 Battery Replacement, Pry up the fabric cover: stap 1, afbeelding 3 van 3
    • Before starting repairs, turn off your device and unplug any cables.
    • The fabric cover of the JBL Flip 6 is secured by plastic clips.
    • Insert the flat end of a spudger into the seam between the two halves of the fabric cover.
    • Push the spudger underneath the edge of the fabric cover without the control panel and pry upwards to release its plastic clips.
    Vraag FixBot
  2. JBL Flip 6 Battery Replacement, Release the plastic clips: stap 2, afbeelding 1 van 3 JBL Flip 6 Battery Replacement, Release the plastic clips: stap 2, afbeelding 2 van 3 JBL Flip 6 Battery Replacement, Release the plastic clips: stap 2, afbeelding 3 van 3
    • Repeat the previous step, using your spudger to work your way along the entire seam to release the remaining plastic clips.
    Vraag FixBot
  3. JBL Flip 6 Battery Replacement, Pry up the fabric cover: stap 3, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Pry up the fabric cover: stap 3, afbeelding 2 van 2
    • Insert the flat end of a spudger underneath the opposite edge of the fabric cover—the side with the control panel.
    • Pry upwards to release the plastic clip.
    Vraag FixBot
  4. JBL Flip 6 Battery Replacement, Release the plastic clips: stap 4, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Release the plastic clips: stap 4, afbeelding 2 van 2
    • Repeat the previous step to release the last plastic clip on the other end of the fabric cover.
    Vraag FixBot
  5. JBL Flip 6 Battery Replacement, Remove the fabric cover: stap 5, afbeelding 1 van 3 JBL Flip 6 Battery Replacement, Remove the fabric cover: stap 5, afbeelding 2 van 3 JBL Flip 6 Battery Replacement, Remove the fabric cover: stap 5, afbeelding 3 van 3
    • Use one hand to spread the edges of the fabric cover apart and your other hand to pull the speaker assembly away from the cover.
    • Remove the fabric cover.
    • During reassembly, this is a good point to power on your device and test your repair before reinstalling the fabric cover.
    Vraag FixBot
  6. JBL Flip 6 Battery Replacement, Unclip the right passive radiator: stap 6, afbeelding 1 van 3 JBL Flip 6 Battery Replacement, Unclip the right passive radiator: stap 6, afbeelding 2 van 3 JBL Flip 6 Battery Replacement, Unclip the right passive radiator: stap 6, afbeelding 3 van 3
    • The right passive radiator is secured by plastic clips and labeled R.
    • Insert the flat end of a spudger underneath the passive radiator housing near one of the plastic clips.
    • Pry upwards to release the first plastic clip holding the passive radiator housing in place.
    Vraag FixBot
  7. JBL Flip 6 Battery Replacement: stap 7, afbeelding 1 van 2 JBL Flip 6 Battery Replacement: stap 7, afbeelding 2 van 2
    • Repeat the previous step to release all of the plastic clips holding the housing in place.
    Vraag FixBot
  8. JBL Flip 6 Battery Replacement, Remove the right passive radiator: stap 8, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Remove the right passive radiator: stap 8, afbeelding 2 van 2
    • Remove the right passive radiator.
    Vraag FixBot
  9. JBL Flip 6 Battery Replacement, Unfasten the safety bracket: stap 9, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Unfasten the safety bracket: stap 9, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the two 9.5 mm-long screws securing the safety bracket.
    Vraag FixBot
  10. JBL Flip 6 Battery Replacement, Remove the safety bracket: stap 10, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Remove the safety bracket: stap 10, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers or your fingers to remove the safety bracket.
    Vraag FixBot
  11. JBL Flip 6 Battery Replacement, Unfasten the woofer: stap 11, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Unfasten the woofer: stap 11, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the four 9.5 mm-long screws securing the woofer.
    • Don't try to remove the woofer all the way yet, as it‘s still connected to the motherboard.
    Vraag FixBot
  12. JBL Flip 6 Battery Replacement, Move the woofer: stap 12, afbeelding 1 van 3 JBL Flip 6 Battery Replacement, Move the woofer: stap 12, afbeelding 2 van 3 JBL Flip 6 Battery Replacement, Move the woofer: stap 12, afbeelding 3 van 3
    • The woofer cables are long enough to allow placing the woofer outside the speaker assembly, but avoid straining or sharply folding the cables when doing so.
    • When handling the woofer, grab it by its edges to avoid damaging the fragile center material.
    • Lift the woofer out of its recess and place it next to the speaker assembly.
    Vraag FixBot
  13. JBL Flip 6 Battery Replacement, Disconnect the woofer: stap 13, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Disconnect the woofer: stap 13, afbeelding 2 van 2
    • The woofer is connected to the motherboard with a JST connector.
    • Use a pair of tweezers to grasp the sides of the woofer connector.
    • Slide the connector out of its socket, gently wiggling it left and right to loosen the clips securing it.
    Vraag FixBot
  14. JBL Flip 6 Battery Replacement, Remove the woofer: stap 14, afbeelding 1 van 1
    • Remove the woofer.
    Vraag FixBot
  15. JBL Flip 6 Battery Replacement, Unfasten the tweeter: stap 15, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Unfasten the tweeter: stap 15, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the two 9.5 mm-long screws securing the tweeter.
    Vraag FixBot
  16. JBL Flip 6 Battery Replacement, Tweeter connector information: stap 16, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Tweeter connector information: stap 16, afbeelding 2 van 2
    • There are different versions of the JBL Flip 6 with different tweeter connectors. Both require a slightly different disconnection procedure.
    • A connector next to the woofer connector, which can be disconnected just like the woofer's.
    • A spade connector with contact springs, which can be disconnected by simply prying up the tweeter.
    • To pry up the tweeter, insert the tip of a spudger between the battery connector and the connector stem of the tweeter and gently press the tweeter upwards to push the stems out of their contact springs.
    • To reconnect the spade connector, just press the contacts back into the springs.
    Vraag FixBot
  17. JBL Flip 6 Battery Replacement, Remove the tweeter: stap 17, afbeelding 1 van 3 JBL Flip 6 Battery Replacement, Remove the tweeter: stap 17, afbeelding 2 van 3 JBL Flip 6 Battery Replacement, Remove the tweeter: stap 17, afbeelding 3 van 3
    • Use a spudger to pry up the tweeter.
    • Remove the tweeter.
    Vraag FixBot
  18. JBL Flip 6 Battery Replacement, Unlatch the power button cable ZIF connector: stap 18, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Unlatch the power button cable ZIF connector: stap 18, afbeelding 2 van 2
    • Use the tip of a spudger or your fingernail to flip up the small, hinged locking flap on the power button cable ZIF connector.
    Vraag FixBot
  19. JBL Flip 6 Battery Replacement, Disconnect the power button cable: stap 19, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Disconnect the power button cable: stap 19, afbeelding 2 van 2
    • Use a pair of tweezers to pull the power button cable out of the ZIF connector.
    Vraag FixBot
  20. JBL Flip 6 Battery Replacement, Unlatch the charging cable ZIF connector: stap 20, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Unlatch the charging cable ZIF connector: stap 20, afbeelding 2 van 2
    • Use the tip of a spudger or your fingernail to flip up the small, hinged locking flap on the charging cable ZIF connector.
    Vraag FixBot
  21. JBL Flip 6 Battery Replacement, Disconnect the charging cable: stap 21, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Disconnect the charging cable: stap 21, afbeelding 2 van 2
    • Use a pair of tweezers to pull the charging cable out of the ZIF connector.
    Vraag FixBot
  22. JBL Flip 6 Battery Replacement, Unlatch the volume button cable ZIF connector: stap 22, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Unlatch the volume button cable ZIF connector: stap 22, afbeelding 2 van 2
    • Use the tip of a spudger or your fingernail to flip up the small, hinged locking flap on the volume button cable ZIF connector.
    Vraag FixBot
  23. JBL Flip 6 Battery Replacement, Disconnect the volume button cable: stap 23, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Disconnect the volume button cable: stap 23, afbeelding 2 van 2
    • Use a pair of tweezers to pull the volume button cable out of the ZIF connector.
    Vraag FixBot
  24. JBL Flip 6 Battery Replacement, Move the motherboard: stap 24, afbeelding 1 van 2 JBL Flip 6 Battery Replacement, Move the motherboard: stap 24, afbeelding 2 van 2
    • Insert a finger into the woofer cutout and press against the left edge of the motherboard.
    • Push the motherboard out of the speaker assembly just until you get free access to the battery connector. You don't need to push it out all the way.
    Vraag FixBot
  25. JBL Flip 6 Battery Replacement, Disconnect the battery: stap 25, afbeelding 1 van 3 JBL Flip 6 Battery Replacement, Disconnect the battery: stap 25, afbeelding 2 van 3 JBL Flip 6 Battery Replacement, Disconnect the battery: stap 25, afbeelding 3 van 3
    • The battery is connected to the motherboard with a power cable connector that has a small tab on the side that locks it in place.
    • Squeeze the tab against the connector, and pull the connector straight up from its socket to disconnect the battery.
    Vraag FixBot
  26. JBL Flip 6 Battery Replacement, Remove the battery: stap 26, afbeelding 1 van 3 JBL Flip 6 Battery Replacement, Remove the battery: stap 26, afbeelding 2 van 3 JBL Flip 6 Battery Replacement, Remove the battery: stap 26, afbeelding 3 van 3
    • Pull the battery out of the speaker assembly to remove it.
    Vraag FixBot
Conclusie
If possible, power on your device and test your repair before reassembly. For optimal performance, calibrate your newly installed battery after completing this guide.
14 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
258.312 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
25.710 handleidingen geschreven
2Gids Commentaar
Donde puedo y me recomiendas comprar la bateria de mi Flip 6
Juan - Antwoord Deel
Yowza! ABSOLUTELY Great directions. THANK YOU!
I Read thru this while trying to decide which small portable Bluetooth speaker to buy. Tired of tossing units because the battery is not replaceable. This JBL Flip 6 IS but >>> WOW - not exactly easy for someone not too experienced. Guess I will just have to learn and gain experience. Sure wish Samsung/JBL made life easier for users tho. The only thing that looks 'iffy' for this speaker is the fraying fabric. I guess nail polish might stop the fraying.
[As for getting back into 'fixing' things - reminds me that when i was 6 i took my Baby Ben Clock apart and after reconstruction there was ONE screw left over. Clock worked for the next 23 years as I moved frm place to place and then it somehow just disappeared (alas). Since then (some 50 yrs) I've always wondered WHY the clock was constructed with an 'extra' screw in the first place]
Abi Woodbridge - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 30
Afgelopen 7 dagen: 162
Afgelopen 30 dagen: 711
Altijd: 21,818
