Ga door naar hoofdinhoud
JBL Flip 3 Front Active Driver Replacement
College Student
College Student en een andere bijdrager
Voor het laatst geüpdatet op December 16, 2019
20 - 25 minuten
Gemiddeld
Wat je nodig hebt
Gereedschap
  • Spudger
    Spudger
  1. JBL Flip 3 Front Active Driver Replacement, Front Active Driver: stap 1, afbeelding 1 van 1
    • Remove plastic outer housing using hands or a standard spudger.
  2. JBL Flip 3 Front Active Driver Replacement: stap 2, afbeelding 1 van 1
    • Using your hands, carefully remove outer housing and frame to expose the internal workings of the speaker.
  3. JBL Flip 3 Front Active Driver Replacement: stap 3, afbeelding 1 van 1
    • Remove the 8.9mm Phillips #00 screws on each corner of the driver to be replaced. There are four screws per driver. Be sure to set the screws somewhere safe to ensure they aren’t lost.
  4. JBL Flip 3 Front Active Driver Replacement: stap 4, afbeelding 1 van 1
    • Remove the 3-pin connector from motherboard.
Conclusie
16 andere personen hebben deze handleiding voltooid.
College Student
3.512 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G2, Leahy Spring 2017 Lid van USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 Leden
18 handleidingen geschreven
7 opmerkingen
where did you source the drivers from?
Rashid Saad Siddiqui - Antwoord
hi my flip 3 1 speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
manu - Antwoord
I too want to know where you can buy new drivers. Can't find them online so far...
Johannes - Antwoord
i need help getting the front speakers only where would i get them???
brian ortiz - Antwoord
Sir
my flip 3 Both speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
Anil Kumar Hembrom - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 50
Altijd: 19,951
