Insignia NS-F12R6-SS Motor Housing Replacing
Inleiding
Ga naar stap 1Removing the motor housing provides access to all of the fan's internal workings.
Wat je nodig hebt
Gereedschap
Unplug your fan.
Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
Use your fingers to gently pull the power knob directly away from the motor housing.
3 andere personen hebben deze handleiding voltooid.
