Ga door naar hoofdinhoud
Imation Superdisk USB Drive Plastic Housing Replacement
Caitlin Horwatt
Caitlin Horwatt en 7 andere bijdragers
Voor het laatst geüpdatet op January 10, 2025
5 - 10 minuten
Eenvoudig
Use this guide to replace an impaired or degraded plastic housing for your Imation Superdisk USB Drive (Model SD-USB-M2).
The plastic housing functions as a protective barrier for internal components of the Superdisk USB Drive. Damage to the plastic housing may result from age or accidental impact. A damaged housing component may require replacement if you encounter difficulty in connecting the drive to a USB port or discover dislodged internal components.
Wat je nodig hebt
Gereedschap
  1. Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: stap 1, afbeelding 1 van 2 Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: stap 1, afbeelding 2 van 2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Plastic Housing Replacement: stap 2, afbeelding 1 van 2 Imation Superdisk USB Drive Plastic Housing Replacement: stap 2, afbeelding 2 van 2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Plastic Housing Replacement: stap 3, afbeelding 1 van 2 Imation Superdisk USB Drive Plastic Housing Replacement: stap 3, afbeelding 2 van 2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Plastic Housing Replacement: stap 4, afbeelding 1 van 2 Imation Superdisk USB Drive Plastic Housing Replacement: stap 4, afbeelding 2 van 2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Plastic Housing Replacement: stap 5, afbeelding 1 van 2 Imation Superdisk USB Drive Plastic Housing Replacement: stap 5, afbeelding 2 van 2
    • Identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
  6. Imation Superdisk USB Drive Plastic Housing Replacement: stap 6, afbeelding 1 van 2 Imation Superdisk USB Drive Plastic Housing Replacement: stap 6, afbeelding 2 van 2
    • Slide the metal housing out of the plastic shell.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Caitlin Horwatt
137 Reputatie
2 handleidingen geschreven
Ohio State, Team 1-2, Buehl Spring 2014 Lid van Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 901
