Ga door naar hoofdinhoud
IdeaPad L340-15API Battery Replacement
Wat je nodig hebt
    1. IdeaPad L340-15API Battery Replacement, Optical Drive: stap 1, afbeelding 1 van 2 IdeaPad L340-15API Battery Replacement, Optical Drive: stap 1, afbeelding 2 van 2
      • Before beginning the repair, make sure that the device is fully powered off.
      • Turn the laptop over so the bottom cover is facing up.
      • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
      Vraag FixBot
      Voeg opmerking toe
    2. IdeaPad L340-15API Battery Replacement: stap 2, afbeelding 1 van 2 IdeaPad L340-15API Battery Replacement: stap 2, afbeelding 2 van 2
      • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
      • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
      Vraag FixBot
      Voeg opmerking toe
    3. IdeaPad L340-15API Battery Replacement: stap 3, afbeelding 1 van 2 IdeaPad L340-15API Battery Replacement: stap 3, afbeelding 2 van 2
      • Place your thumb at the seam between the optical drive and the device.
      • Gently pull the component straight out from the device, taking care not to pull at an angle.
      Vraag FixBot
      Voeg opmerking toe
    1. IdeaPad L340-15API Battery Replacement, Battery: stap 4, afbeelding 1 van 2 IdeaPad L340-15API Battery Replacement, Battery: stap 4, afbeelding 2 van 2
      • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
      Vraag FixBot
      Voeg opmerking toe
    2. IdeaPad L340-15API Battery Replacement: stap 5, afbeelding 1 van 3 IdeaPad L340-15API Battery Replacement: stap 5, afbeelding 2 van 3 IdeaPad L340-15API Battery Replacement: stap 5, afbeelding 3 van 3
      • Insert a plastic opening pick in the back left corner and wedge the panel open.
      • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
      • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
      • Remove the bottom cover.
      Vraag FixBot
      Voeg opmerking toe
    3. IdeaPad L340-15API Battery Replacement: stap 6, afbeelding 1 van 2 IdeaPad L340-15API Battery Replacement: stap 6, afbeelding 2 van 2
      • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
      • Use a container/magnet strip to store the screws while working.
      Vraag FixBot
      Voeg opmerking toe
    4. IdeaPad L340-15API Battery Replacement: stap 7, afbeelding 1 van 3 IdeaPad L340-15API Battery Replacement: stap 7, afbeelding 2 van 3 IdeaPad L340-15API Battery Replacement: stap 7, afbeelding 3 van 3
      • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
      • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
      Vraag FixBot
      Voeg opmerking toe
    5. IdeaPad L340-15API Battery Replacement: stap 8, afbeelding 1 van 1
      • Remove the battery from the laptop.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Ian
347 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-5, Bowman Fall 2025 Lid van UMass Dartmouth, Team 2-5, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G5
4 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 57
Altijd: 393
