Huawei P10 Lite Loudspeaker / Vibration Motor Replacement
Inleiding
Ga naar stap 1Use this guide to replace the loudspeaker and/or the vibration motor in your Huawei P10 Lite smartphone. When reassembling your phone apply new adhesive where it is necessary.
Wat je nodig hebt
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
Remove the Phillips screw holding the battery connector plate in place.
Remove the battery connector plate.
Use the flat end of a spudger to disconnect the battery flex cable.
Use an iOpener to loosen the glue under the vibration motor.
Remove the vibration motor.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
is it necessary to disconnect the finger print sensor flex cable in order to remove/replace the loudspeaker, or is just a precaution!?
