Huawei P10 Lite Charging Board Replacement
Inleiding
Ga naar stap 1Use this guide to replace the charging board in your Huawei P10 Lite smartphone. When reassembling your phone apply new adhesive where it is necessary.
Wat je nodig hebt
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
Remove the Phillips screw holding the battery connector plate in place.
Remove the battery connector plate.
Use the flat end of a spudger to disconnect the battery flex cable.
Use an iOpener to loosen the glue under the vibration motor.
Remove the vibration motor.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use the flat end of a spudger to disconnect the interconnect cable.
Use tweezers to disconnect the antenna cable.
Use an iOpener to loosen the adhesive under the charging board.
Remove the charging board.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
5 andere personen hebben deze handleiding voltooid.
