Ga door naar hoofdinhoud
How to fix a torn piece of fabric
Kris McLemore
Kris McLemore en 2 andere bijdragers
Voor het laatst geüpdatet op August 2, 2024
15 minuten
Eenvoudig
Sew and needle was the first form of sewing that was invented before sewing machines. The only requirements needed are a sewing needle, thread to match the fabric you are repairing and come patience. The only hazard when preforming this is making sure not to pock your finger while sowing. This is a needed skill to know because most don't know how to use sowing machines so it is an easy in home solution to torn fabrics.
Wat je nodig hebt
iFixit krijgt commissie als je dingen koopt via deze links.
  1. How to fix a torn piece of fabric, Torn Fabrics: stap 1, afbeelding 1 van 1
    • The tools needed are in the following pictures. Make sure the fabric you are using matches the fabric being repaired if its clothing.
  2. How to fix a torn piece of fabric: stap 2, afbeelding 1 van 1
    • Press the thread through the hole of the needle. Getting the end of the needle wet will help it through easier. Once that is done make a firm knot to hold it in place.
  3. How to fix a torn piece of fabric: stap 3, afbeelding 1 van 1
    • Place the new fabric on top of the torn fabric and poke the needle through the end of the tear. Make sure to make a knot to hold the first incision through.
  4. How to fix a torn piece of fabric: stap 4, afbeelding 1 van 1
    • Began looping your thread through the new fabric on top of the torn fabric.
  5. How to fix a torn piece of fabric: stap 5, afbeelding 1 van 1
    • Take your time looping the thread through and make sure it is secured.
  6. How to fix a torn piece of fabric: stap 6, afbeelding 1 van 1
    • Once at the end of the fabric make a secured knot and cut any extra fabric left.
  7. How to fix a torn piece of fabric: stap 7, afbeelding 1 van 1
    • Look at your finished project to make sure it is clean.
Conclusie
Kris McLemore
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 743
