Ga door naar hoofdinhoud
How to fix a ripped back pocket of jeans
Ashley Dembroski
Ashley Dembroski en een andere bijdrager
Voor het laatst geüpdatet op July 16, 2021
15 - 30 minuten
Gemiddeld
Use this guide to help you repair your ripped back pocket in your jeans.
In this guide you will need your ripped back pocket jeans. The reason this guide is needed is because back pockets are important to hold things such as your wallet, keys or cell phone.
There is no real special skills needed for this fix, my hope is that this guide will be enough that any person can sew their ripped jeans.
  1. How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: stap 1, afbeelding 1 van 3 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: stap 1, afbeelding 2 van 3 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: stap 1, afbeelding 3 van 3
    • Pin down the ripped portion of the jeans back pocket.
    • Use as many pins as needed to ensure the pocket does not slip from the correct place while sewing.
  2. How to fix a ripped back pocket of jeans: stap 2, afbeelding 1 van 2 How to fix a ripped back pocket of jeans: stap 2, afbeelding 2 van 2
    • Thread the needle with the polyester thread.
    • Use about an arms length of thread to ensure that you have enough to sew with.
  3. How to fix a ripped back pocket of jeans: stap 3, afbeelding 1 van 1
    • Cut the ends of the thread.
  4. How to fix a ripped back pocket of jeans: stap 4, afbeelding 1 van 2 How to fix a ripped back pocket of jeans: stap 4, afbeelding 2 van 2
    • Tie a double knot at the end of the two threads.
  5. How to fix a ripped back pocket of jeans: stap 5, afbeelding 1 van 2 How to fix a ripped back pocket of jeans: stap 5, afbeelding 2 van 2
    • Start to sew from the bottom of the pocket up.
  6. How to fix a ripped back pocket of jeans: stap 6, afbeelding 1 van 2 How to fix a ripped back pocket of jeans: stap 6, afbeelding 2 van 2
    • Remove pins as the needle and thread approaches the pins.
  7. How to fix a ripped back pocket of jeans: stap 7, afbeelding 1 van 3 How to fix a ripped back pocket of jeans: stap 7, afbeelding 2 van 3 How to fix a ripped back pocket of jeans: stap 7, afbeelding 3 van 3
    • Loop the needle through the thread to tie a knot to end and secure the sewing.
  8. How to fix a ripped back pocket of jeans: stap 8, afbeelding 1 van 1
    • Cut the loose threads to clean up the sewing.
Conclusie
Ashley Dembroski
157 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G2, Cardinal Summer 2020 Lid van UW Tacoma, Team S1-G2, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G2
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 37
Altijd: 4,091
