Ga door naar hoofdinhoud
How to easily fix a Xbox 360 drive that wont open.
Matt Weatherly
Matt Weatherly en 2 andere bijdragers
Voor het laatst geüpdatet op May 7, 2024
10 - 20 minuten
Eenvoudig
Door de gemeenschap gemaakte handleiding
Wat je nodig hebt
iFixit krijgt commissie als je dingen koopt via deze links.
  1. How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: stap 1, afbeelding 1 van 2 How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: stap 1, afbeelding 2 van 2
    • First we need to take off the face plate.
  2. How to easily fix a Xbox 360 drive that wont open.: stap 2, afbeelding 1 van 1
    • Use a paper clip or a long pick tool to manually open DVD Drive.
  3. How to easily fix a Xbox 360 drive that wont open.: stap 3, afbeelding 1 van 2 How to easily fix a Xbox 360 drive that wont open.: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to take a rubber belt of 2 pulleys in between the hole in the DVD Tray.
  4. How to easily fix a Xbox 360 drive that wont open.: stap 4, afbeelding 1 van 2 How to easily fix a Xbox 360 drive that wont open.: stap 4, afbeelding 2 van 2
    • Use a damp paper towel to thoroughly clean the rubber belt.
  5. How to easily fix a Xbox 360 drive that wont open.: stap 5, afbeelding 1 van 1
    • Use the tweezers to put the rubber belt back on the 2 pulleys we took them off of.
    • I have found it is easier to start with the big pulley first then once around the big pulley get the belt around the small belt.
  6. How to easily fix a Xbox 360 drive that wont open.: stap 6, afbeelding 1 van 2 How to easily fix a Xbox 360 drive that wont open.: stap 6, afbeelding 2 van 2
    • Close the DVD Drive and put the face plate back on.
    • Plug the system in and test to see if the drive works.
Conclusie
These steps have helped me fix 2 original Xbox systems and 3 Xbox 360 systems. I hope it helps yall. If you need any clarification on any of the steps please message me.
15 andere personen hebben deze handleiding voltooid.
Matt Weatherly
1.332 Reputatie
2 handleidingen geschreven
8 opmerkingen
the picture of the exbox is not mine
dongwillows - Antwoord
the picture you show is not my console
My xbox 360 console looks like this but does not have a hole to manually open the tray.
Don - Antwoord
It had to use different tools to open and clean the rubber pulley with 70% Alcohol. Thank you for posting it i fixed my 2009 Black xbox 360 Console.
Gustavo Montes - Antwoord
How did you open your Xbox? Because mine also doesn’t have that hole
Astr0 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 156
Altijd: 12,611
