Ga door naar hoofdinhoud
How to Tailor Pants Waistband
Maya Leonard
Maya Leonard en 3 andere bijdragers
Voor het laatst geüpdatet op December 20, 2024
1 - 2 uren
Gemiddeld
Do your pants no longer fit comfortably at the waistband? This guide will show you how to adjust the waistband using a dart hand-stitching technique, whether it's too loose or tight. This repair is ideal for tailoring pants to a better fit without specialized sewing equipment.
What You Need to Know Before You Begin:
Skill Level: This guide is suitable for beginners with basic hand-sewing skills.
Potential Hazards: Sharp tools such as scissors and needles will be used, so proceed with caution to avoid injury.
Common Reasons for This Repair: Waistbands often require adjustments due to weight changes, clothing stretching over time, or purchasing ill-fitting pants.
Tips for Success:
Mark the dart position carefully to ensure symmetry and alignment.
Practice the basting and regular stitch on a scrap fabric piece if you’re unfamiliar with the techniques.
For delicate or stretchy fabrics, consider using a stabilizer to prevent puckering.
Before you begin, start off by cleaning your workspace, and then gather all the necessary tools and materials. Follow this tutorial to give your pants a whole new look and provide you with a professional look and comfort with a customized fit.
  1. How to Tailor Pants Waistband, How to Tailor Pants Waistband: stap 1, afbeelding 1 van 1
    • Pinch the back of the pants until they fit how you want.
  2. How to Tailor Pants Waistband: stap 2, afbeelding 1 van 1
    • Mark with fabric chalk on either side of the back seam where the two sides of fabric meet when you pinch the waistband to fit well.
  3. How to Tailor Pants Waistband: stap 3, afbeelding 1 van 2 How to Tailor Pants Waistband: stap 3, afbeelding 2 van 2
    • Rip the back seam, waistband, and any belt loops using a seam ripper
    • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury.
    • Keep fingers away from the path of the seam ripper and seam rip away from yourself at all times.
  4. How to Tailor Pants Waistband: stap 4, afbeelding 1 van 2 How to Tailor Pants Waistband: stap 4, afbeelding 2 van 2
    • Pinch together where the chalk marks are.
  5. How to Tailor Pants Waistband: stap 5, afbeelding 1 van 1
    • Pin on the inside of where you are holding the marks together with at least 3⁄8” of space on the open side of the seam ripped area.
  6. How to Tailor Pants Waistband: stap 6, afbeelding 1 van 2 How to Tailor Pants Waistband: stap 6, afbeelding 2 van 2
    • Stitch in large basting stitches on the inside of the pants along where you pinned.
    • Basting stitches are long stitches that are easily removable.
  7. How to Tailor Pants Waistband: stap 7, afbeelding 1 van 1
    • Try on the pants to see if they fit.
    • If they don’t, take out the stitches you made and adjust until they do.
    • If they fit, then you can proceed!
  8. How to Tailor Pants Waistband: stap 8, afbeelding 1 van 2 How to Tailor Pants Waistband: stap 8, afbeelding 2 van 2
    • Sew smaller stitches along where your basting stitches were.
    • Take out the pins after you are finished sewing.
  9. How to Tailor Pants Waistband: stap 9, afbeelding 1 van 1
    • Cut the extra fabric on the inside of the pants while leaving 3/8" of space between the scissors and stitches.
    • If you think you may need to adjust these pants again in the future then you can choose to skip this step.
  10. How to Tailor Pants Waistband: stap 10, afbeelding 1 van 1
    • Try on your new, well-fitting pants!
Conclusie
If the size needs to be changed at a later time, you can always take out the seams and readjust.
Maya Leonard
181 Reputatie
1 Handleiding geschreven
UC Davis, Team 1-5, Vidal-Chiesa Fall 2024 Lid van UC Davis, Team 1-5, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S1G5
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 55
