Ga door naar hoofdinhoud
How to Replace the Screen Adhesive for Your Google Pixel 7
Wat je nodig hebt
  1. How to Replace the Screen Adhesive for Your Google Pixel 7, Clean the frame: stap 1, afbeelding 1 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Clean the frame: stap 1, afbeelding 2 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Clean the frame: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Microfiber Cleaning Cloths
    $3.99
    • Any residual adhesive or debris will prevent your screen from sealing properly.
    • Use the flat end of your spudger to scrape off as much adhesive as you can.
    • Use caution not to damage the spring connectors near the perimeter of the frame.
    • Use tweezers or your fingers to peel and remove any remaining adhesive.
    • Clean the perimeter of the frame with a small amount of highly-concentrated isopropyl alcohol (over 90%) and a lint-free or microfiber cloth.
  2. How to Replace the Screen Adhesive for Your Google Pixel 7, Clean the screen: stap 2, afbeelding 1 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Clean the screen: stap 2, afbeelding 2 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Clean the screen: stap 2, afbeelding 3 van 3
    • If you're reusing your screen, clean it as you did for the frame.
  3. How to Replace the Screen Adhesive for Your Google Pixel 7, Orient the adhesive: stap 3, afbeelding 1 van 2 How to Replace the Screen Adhesive for Your Google Pixel 7, Orient the adhesive: stap 3, afbeelding 2 van 2
    • Before applying the new adhesive, lay it over the frame to find its proper orientation.
    • Use features such as the upper loudspeaker cutout, lower left hole, and upper right hole to orient the adhesive.
  4. How to Replace the Screen Adhesive for Your Google Pixel 7, Remove the adhesive backing: stap 4, afbeelding 1 van 1
    • Use the pull tab on the top of the adhesive to remove the protective backing.
    • This will expose the adhesive that sticks to the frame.
  5. How to Replace the Screen Adhesive for Your Google Pixel 7, Apply the adhesive: stap 5, afbeelding 1 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Apply the adhesive: stap 5, afbeelding 2 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Apply the adhesive: stap 5, afbeelding 3 van 3
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lay the adhesive onto the frame, starting with the bottom or top edge. Make small corrections as you go.
    • There are holes in the bottom left and top right corners to help align the adhesive.
  6. How to Replace the Screen Adhesive for Your Google Pixel 7: stap 6, afbeelding 1 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7: stap 6, afbeelding 2 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7: stap 6, afbeelding 3 van 3
    • Use a spudger or your fingers to firmly press along the perimeter of the adhesive and adhere it to the frame.
    • Be careful not to damage the spring connectors near the perimeter of the frame.
  7. How to Replace the Screen Adhesive for Your Google Pixel 7, Remove the liners: stap 7, afbeelding 1 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Remove the liners: stap 7, afbeelding 2 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Remove the liners: stap 7, afbeelding 3 van 3
    • Grab the pull tab on the upper left of the frame and peel off the main liner.
  8. How to Replace the Screen Adhesive for Your Google Pixel 7, Check for liners: stap 8, afbeelding 1 van 1
    • If you replaced the screen, check the front-facing camera hole and sensor cutout on the replacement screen and remove any remaining protective liners in it.
  9. How to Replace the Screen Adhesive for Your Google Pixel 7, Continue reassembly: stap 9, afbeelding 1 van 1
    • Return to your phone's guide and continue reassembly.
    • Remember to reinstall the screen connector bracket.
    • Finish this guide when your screen is installed and you're ready to seal the phone up.
  10. How to Replace the Screen Adhesive for Your Google Pixel 7, Remove the final liner: stap 10, afbeelding 1 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Remove the final liner: stap 10, afbeelding 2 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Remove the final liner: stap 10, afbeelding 3 van 3
    • Take care not to puncture the battery with your tweezers—a punctured battery may leak dangerous chemicals or cause a fire.
    • Grab the pull tab on the lower right of the frame and peel off the liner covering the perimeter adhesive.
    • Make sure the adhesive doesn't peel up with the liner.
  11. How to Replace the Screen Adhesive for Your Google Pixel 7, Install the screen: stap 11, afbeelding 1 van 2 How to Replace the Screen Adhesive for Your Google Pixel 7, Install the screen: stap 11, afbeelding 2 van 2
    • Flip the screen over and lay it onto the frame.
    • Press along the perimeter of the screen to secure it.
  12. How to Replace the Screen Adhesive for Your Google Pixel 7, Strengthen the adhesive bond: stap 12, afbeelding 1 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Strengthen the adhesive bond: stap 12, afbeelding 2 van 3 How to Replace the Screen Adhesive for Your Google Pixel 7, Strengthen the adhesive bond: stap 12, afbeelding 3 van 3
    Screen Vise Clamps 6-Pack
    $15.99
    • To evenly compress your Pixel and strengthen the bond of the screen to the frame, you need to account for the camera bar.
    • If you have screen vise clamps, you can work around the camera bar. Secure the clamps to the perimeter of the device.
    • Apply tape to the perimeter of your rear glass to protect its finish.
    • Place coins or similarly thick objects along the edges of the rear glass. Make sure they're as thick or thicker than the camera bar.
    • Stack multiple books or other heavy objects on your phone. Leave them in place for thirty minutes or longer. Ideally, leave them stacked overnight.
Eindstreep
21 andere personen hebben deze handleiding voltooid.
Arthur Shi
283.381 Reputatie
587 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.637 handleidingen geschreven
3Gids Commentaar
Fantastic guide. Read through it first. Go slowly and re-read each section as you do it. Get the iFixit tools. They are invaluable.
msqualls - Antwoord
Do not force anything during any step of this guide. Like most sensitive electronics, force is rarely if ever required.
Take your time, be patient, if something is proving to be tricky take a small break and come back to it in a few minutes.
Things I felt should be included in guide or I had issue with:
1. You might end up cracking or breaking the original screen as you insert the pry tools. If replacing the whole screen, this should not matter to you and it’s ok if you notice cracks or breaks.
2. You want to aim for under the black plastic frame that is UNDER the screen to insert your pry tool.
3. Have extra alcohol wipes or isopropyl alcohol on hand. Repair kit only comes with 1 wipe (seriously??). You can use goo gone if you have some but USE SPARINGLY DO NOT SATURATE. Allow time to air out and evaporate before applying new adhesive. I was able to remove about 95% of old adhesive this way.
4. When you think you’re ready to reassemble, don’t forget the bracket and adhesive before sealing the new screen!!!
Zachary (Zach) - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 95
Afgelopen 30 dagen: 449
Altijd: 11,142
