Ga door naar hoofdinhoud
How to Repair a Belt Loop on Dress Pants
Allyson Lahnala
Allyson Lahnala en 2 andere bijdragers
Voor het laatst geüpdatet op June 11, 2024
15 minuten
Eenvoudig
This is a guide on how repair or reattach a belt loop on a pair of dress pants. For this repair you will need a sewing machine, thread, scissors, and sewing pins (optional). When sewing, make sure you are not wearing loose clothing and tie back hair that could get caught in the machine. This is a useful repair because dress pants can be expensive to replace if a piece goes missing or is damaged, and this repair can make it less likely for you to need to replace your dress pants.
  1. How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: stap 1, afbeelding 1 van 3 How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: stap 1, afbeelding 2 van 3 How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: stap 1, afbeelding 3 van 3
    • Thread the sewing machine with a thread that matches your pants.
    • Thread via your sewing machine instructions. They can be marked on your machine, or in a separate pamphlet.
  2. How to Repair a Belt Loop on Dress Pants: stap 2, afbeelding 1 van 3 How to Repair a Belt Loop on Dress Pants: stap 2, afbeelding 2 van 3 How to Repair a Belt Loop on Dress Pants: stap 2, afbeelding 3 van 3
    • Remove the extension table from the sewing machine.
  3. How to Repair a Belt Loop on Dress Pants: stap 3, afbeelding 1 van 1
    • Pin the belt loop seam side up so that the top of the loop is 1/4 inch above the seam.
  4. How to Repair a Belt Loop on Dress Pants: stap 4, afbeelding 1 van 3 How to Repair a Belt Loop on Dress Pants: stap 4, afbeelding 2 van 3 How to Repair a Belt Loop on Dress Pants: stap 4, afbeelding 3 van 3
    • Sew using a straight stitch along the seam.
    • Use the reverse feature on the sewing machine to go over the stitches three times.
    • Once the sewing foot is down and the needle is in the fabric you can remove the pin.
  5. How to Repair a Belt Loop on Dress Pants: stap 5, afbeelding 1 van 3 How to Repair a Belt Loop on Dress Pants: stap 5, afbeelding 2 van 3 How to Repair a Belt Loop on Dress Pants: stap 5, afbeelding 3 van 3
    • Remove the pants from the sewing machine by cutting the threads.
  6. How to Repair a Belt Loop on Dress Pants: stap 6, afbeelding 1 van 1
    • Fold the interfacing over so that it is out of the way of the needle.
    • If the pants do not have interfacing, this step can be skipped.
  7. How to Repair a Belt Loop on Dress Pants: stap 7, afbeelding 1 van 2 How to Repair a Belt Loop on Dress Pants: stap 7, afbeelding 2 van 2
    • Sew the belt loop a 1/4 inch below the seam using a straight stitch.
    • Use the reverse feature to go over the stitches three times.
  8. How to Repair a Belt Loop on Dress Pants: stap 8, afbeelding 1 van 1
  9. How to Repair a Belt Loop on Dress Pants: stap 9, afbeelding 1 van 1
    • Fold the belt loop over.
  10. How to Repair a Belt Loop on Dress Pants: stap 10, afbeelding 1 van 3 How to Repair a Belt Loop on Dress Pants: stap 10, afbeelding 2 van 3 How to Repair a Belt Loop on Dress Pants: stap 10, afbeelding 3 van 3
    • Trim the belt loop's excess length so that there is a 1/4 inch overlap.
  11. How to Repair a Belt Loop on Dress Pants: stap 11, afbeelding 1 van 1
    • Pin the folded belt loop to the top of the waistband.
  12. How to Repair a Belt Loop on Dress Pants: stap 12, afbeelding 1 van 2 How to Repair a Belt Loop on Dress Pants: stap 12, afbeelding 2 van 2
    • Sew the top of the belt loop with an 1/8 inch seam allowance, using a straight stitch.
    • Use the reverse feature on the sewing machine and go over the stitches three times.
  13. How to Repair a Belt Loop on Dress Pants: stap 13, afbeelding 1 van 3 How to Repair a Belt Loop on Dress Pants: stap 13, afbeelding 2 van 3 How to Repair a Belt Loop on Dress Pants: stap 13, afbeelding 3 van 3
  14. How to Repair a Belt Loop on Dress Pants: stap 14, afbeelding 1 van 1
    • Trim any remaining threads.
Eindstreep
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 219
