Inleiding
Your jacket has got your back. It follows you on adventures, keeping you warm and dry even through the stormiest weather. Return the favor by periodically refreshing its durable water repellent (DWR) coating!
DWR is your jacket's first line of waterproof defense, causing water droplets to bead up and roll off the surface of the fabric instead of soaking in. Over time, dirt, oil, and regular use can wear down this protective layer, allowing water to seep into the fabric.
This guide will show you how to reapply a DWR coating using Storm Eco Proofer, a Patagonia® recommended product. With just a few simple steps, you can restore your jacket’s water repellency and keep it adventure-ready!
Related Tutorials
- Test for Water Repellency
- Wash a Waterproof Jacket
- Iron a Waterproof Jacket
- Wash and Dry a Patagonia Down Jacket
Related Wikis
Wat je nodig hebt
Zip up all zippers to protect them during the wash and dry cycles.
Check all pockets for forgotten items and hidden treasures!
Place the jacket in the washing machine.
Ideally, use a front-loading washer instead of a top-loading machine.
Add durable water repellent treatment to the wash, following the instructions on the bottle.
For Patagonia® recommended Storm Eco Proofer:
Shake the bottle and measure out 2.5 ounces (75 ml) (about 1/3 cup or 5 tablespoons) per item.
Pour the treatment into the fabric softener compartment.
You can add Storm Clothing Wash to the detergent compartment. It’s designed to work with the Eco Proofer.
Set the load size to small or medium, depending on the number of garments you're washing.
Set the water temperature to cold.
Set the wash cycle to normal or gentle/delicate/permanent press. If possible, add an extra rinse cycle to ensure all residues are removed.
Set the spin cycle to low.
Start the washing machine.
Hang the jacket up to drip dry first to remove excess water.
Tumble dry the jacket on low heat.
Follow the garment care instructions for dryer time settings. While a lightweight rain shell may only take 20 minutes, a down insulated jacket could take up to 2 hours to fully dry.
Your jacket is now refreshed and ready to take on the elements again. Whether you're heading into the mountains, the forest, or just out for a rainy-day walk, your gear is good to go.
Get back out there!
Spray-on treatments are great for targeted reapplication or when you want to avoid a full wash. Follow the instructions on the bottle, which typically include:
Spray onto a freshly cleaned garment while it's hanging or laid flat.
Focus the spray on high-wear areas like shoulders.
Let it sit for a few minutes, then heat-set it with a dryer or iron.
Reapply DWR when water no longer beads on the surface of your jacket. This can vary based on use, but typically every 6–12 months or after every few washes.
For even more info on waterproof and water-resistant gear, how it works, how to care for it, and how to know when it needs maintenance or replacement, see Caring for Water-Resistant Gear.
8 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
Can you recommend a durable water repellency treatment? I have tried to treat my rain jacket in the past and have been disappointed in the results.
If fabric becomes wet, it loses its performance and breathability indeed. Therefore, most technical garments contain a tiny layer of Durable Water Repellency (DWR) coating outside. This layer of liquid prevents dirt, grease, oil, and water as well. But, usually, protecting this essential fabric layer becomes very difficult yet.
Therefore, some people use the best waterproofing spray for the outdoor fabric to protect this liquid coating. These waterproofing sprays protect our footwear, and other clothing stuffs from water damage. Though this spray’s main function is to prevent water and form a protective barrier against sun and dirt, it has more benefits than one. These waterproofing sprays improve the performance of your fabrics.
For More Information & Products Review and Buying Guide Visit - https://www.bestoutdoorreview.com/best-w...
