Ga door naar hoofdinhoud
How to Iron a Waterproof Jacket
Wat je nodig hebt
    1. How to Iron a Waterproof Jacket, Prepare the jacket: stap 1, afbeelding 1 van 1
      • Unzip your clean jacket and slide one half over your ironing board or towel-covered surface.
      • You only want to iron through one layer of the jacket at a time. Ironing through two layers can create creases in the bottom layer.
      • Flatten your jacket with your hands.
      Vraag FixBot
      Voeg opmerking toe
    2. How to Iron a Waterproof Jacket, Set up the iron: stap 2, afbeelding 1 van 3 How to Iron a Waterproof Jacket, Set up the iron: stap 2, afbeelding 2 van 3 How to Iron a Waterproof Jacket, Set up the iron: stap 2, afbeelding 3 van 3
      • Set the iron to its lowest heat setting, below 230 °F.
      • Turn off the steam function. Steam can damage the fabric and the DWR coating. If you can't turn off the steam function on your iron, drain the water chamber completely.
      Vraag FixBot
      Voeg opmerking toe
    3. How to Iron a Waterproof Jacket, Protect the jacket: stap 3, afbeelding 1 van 2 How to Iron a Waterproof Jacket, Protect the jacket: stap 3, afbeelding 2 van 2
      Vraag FixBot
      Voeg opmerking toe
    4. How to Iron a Waterproof Jacket, Iron the jacket: stap 4, afbeelding 1 van 2 How to Iron a Waterproof Jacket, Iron the jacket: stap 4, afbeelding 2 van 2
      • Iron in one smooth stroke, running parallel to the zipper.
      • Only iron in one direction, don't go back and forth or you risk creating creases. Change directions only when you move to a new section of the jacket.
      • Don't press down. Let the heat and weight of the iron do the work.
      • Keep the iron moving continuously to avoid melting or burning the fabric.
      Vraag FixBot
      Voeg opmerking toe
    5. How to Iron a Waterproof Jacket, Check your progress: stap 5, afbeelding 1 van 3 How to Iron a Waterproof Jacket, Check your progress: stap 5, afbeelding 2 van 3 How to Iron a Waterproof Jacket, Check your progress: stap 5, afbeelding 3 van 3
      • Remove the towel and inspect the jacket.
      • If the fabric looks unchanged, increase the heat slightly and try again.
      • If the area looks smooth, move on to the next section.
      Vraag FixBot
      Voeg opmerking toe
      • To fully reactivate the DWR coating, heat must make contact with every part of the jacket. Go slowly and work in small, manageable sections to ensure even coverage.
      • Be extra careful around tight or curved areas like hoods, cuffs, and sleeves.
      • For the sleeves, slide a tailor’s ham, sleeve board, or folded towel inside the sleeve to separate the two sides.
      • Continue repositioning the jacket and repeating the ironing process until the entire surface has been treated.
      • Don't forget to turn off the iron when you're finished.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
24 andere personen hebben deze handleiding voltooid.
Clara Redwood
2.568 Reputatie
19 handleidingen geschreven
Patagonia Lid van Patagonia
Community
9 Leden
289 handleidingen geschreven
17Gids Commentaar
Thank you, good advice for younger generation who have clue.
keirakeith26 - Antwoord Deel
Thank you - good reminder for the older generation who have lost their marbles
Swag McYolo - Antwoord Deel
Thank you- good reminder for the baby boomer middle aged who voted for Brexit and haven't got a clue.
fixxysugar - Antwoord Deel
謝謝,對於說中文的外國人來說,這是一個很好的建議,即使他們沒有失去彈珠,他們也沒有投棄權,但仍然沒有任何線索。
艾爾伯特愛因斯坦 - Antwoord Deel
I hope the non-English comment is also in the same form as the first 3.
Eva - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 20
Afgelopen 7 dagen: 123
Afgelopen 30 dagen: 539
Altijd: 204,088
