Ga door naar hoofdinhoud
How to Lubricate a Zipper
Brittany McCrigler
Brittany McCrigler en 4 andere bijdragers
Voor het laatst geüpdatet op March 9, 2025
5 minuten
Zeer eenvoudig
The most common reason zippers get stuck is that dirt and debris often lodges in the zipper slider. Cleaning and lubricating your zipper helps to extend its life and prevents sticking, oxidizing, and jamming. The procedure we describe here works for both coil zippers and plastic tooth zippers. Lubricate your zipper after you’ve been in a dusty, dirty or wet environment.
Wat je nodig hebt
  1. How to Lubricate a Zipper, How to Lubricate a Zipper: stap 1, afbeelding 1 van 3 How to Lubricate a Zipper, How to Lubricate a Zipper: stap 1, afbeelding 2 van 3 How to Lubricate a Zipper, How to Lubricate a Zipper: stap 1, afbeelding 3 van 3
    • Lay your garment on a table.
    • If you can, unzip the zipper.
    • If you can't move the slider, just work around it.
    • Using the brush located on top of the Zip Care bottle, or simply using a nylon brush, work the dirt and debris off of the zipper coil or the teeth of the zipper.
  2. How to Lubricate a Zipper: stap 2, afbeelding 1 van 2 How to Lubricate a Zipper: stap 2, afbeelding 2 van 2
    • Pinch the slider in your fingers, so that you can see into the area where the coil rests.
    • Use the brush to free any dirt or debris caught inside the slider.
  3. How to Lubricate a Zipper: stap 3, afbeelding 1 van 3 How to Lubricate a Zipper: stap 3, afbeelding 2 van 3 How to Lubricate a Zipper: stap 3, afbeelding 3 van 3
    • Place a paper towel behind the zipper.
    • To prevent messes, make sure that the paper towel is touching the underside of the teeth or coil.
  4. How to Lubricate a Zipper: stap 4, afbeelding 1 van 3 How to Lubricate a Zipper: stap 4, afbeelding 2 van 3 How to Lubricate a Zipper: stap 4, afbeelding 3 van 3
    • Twist open the Zip Care.
    • Gently squeeze the bottle as you slide the brush along the teeth or coil of the zipper to apply the lubricant.
    • Repeat this on both sides of the zipper teeth or coil.
  5. How to Lubricate a Zipper: stap 5, afbeelding 1 van 2 How to Lubricate a Zipper: stap 5, afbeelding 2 van 2
    • Fold the paper towel over and dab any excess lubricant off the zipper.
  6. How to Lubricate a Zipper: stap 6, afbeelding 1 van 2 How to Lubricate a Zipper: stap 6, afbeelding 2 van 2
    • Zip and unzip the zipper a few times to work the lubricant in between the teeth or coil.
Eindstreep
6 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.769 Reputatie
142 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.550 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 90
Afgelopen 30 dagen: 432
Altijd: 117,607
