Ga door naar hoofdinhoud
How to Lubricate a Zipper
Wat je nodig hebt
    1. How to Lubricate a Zipper, How to Lubricate a Zipper: stap 1, afbeelding 1 van 3 How to Lubricate a Zipper, How to Lubricate a Zipper: stap 1, afbeelding 2 van 3 How to Lubricate a Zipper, How to Lubricate a Zipper: stap 1, afbeelding 3 van 3
      • Lay your garment on a table.
      • If you can, unzip the zipper.
      • If you can't move the slider, just work around it.
      • Using the brush located on top of the Zip Care bottle, or simply using a nylon brush, work the dirt and debris off of the zipper coil or the teeth of the zipper.
      Vraag FixBot
      Voeg opmerking toe
    2. How to Lubricate a Zipper: stap 2, afbeelding 1 van 2 How to Lubricate a Zipper: stap 2, afbeelding 2 van 2
      • Pinch the slider in your fingers, so that you can see into the area where the coil rests.
      • Use the brush to free any dirt or debris caught inside the slider.
      Vraag FixBot
      Voeg opmerking toe
    3. How to Lubricate a Zipper: stap 3, afbeelding 1 van 3 How to Lubricate a Zipper: stap 3, afbeelding 2 van 3 How to Lubricate a Zipper: stap 3, afbeelding 3 van 3
      • Place a paper towel behind the zipper.
      • To prevent messes, make sure that the paper towel is touching the underside of the teeth or coil.
      Vraag FixBot
      Voeg opmerking toe
    4. How to Lubricate a Zipper: stap 4, afbeelding 1 van 3 How to Lubricate a Zipper: stap 4, afbeelding 2 van 3 How to Lubricate a Zipper: stap 4, afbeelding 3 van 3
      • Twist open the Zip Care.
      • Gently squeeze the bottle as you slide the brush along the teeth or coil of the zipper to apply the lubricant.
      • Repeat this on both sides of the zipper teeth or coil.
      Vraag FixBot
      Voeg opmerking toe
    5. How to Lubricate a Zipper: stap 5, afbeelding 1 van 2 How to Lubricate a Zipper: stap 5, afbeelding 2 van 2
      • Fold the paper towel over and dab any excess lubricant off the zipper.
      Vraag FixBot
      Voeg opmerking toe
    6. How to Lubricate a Zipper: stap 6, afbeelding 1 van 2 How to Lubricate a Zipper: stap 6, afbeelding 2 van 2
      • Zip and unzip the zipper a few times to work the lubricant in between the teeth or coil.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
6 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
91.030 Reputatie
142 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
59.744 handleidingen geschreven
1Gids Commentaar
Hi Brittany, I’m hoping you have an answer for my favourite purse. The zipper is frozen due to the remnant of a plastic bag I put in my purse. Please advise!
Clair - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 56
Afgelopen 30 dagen: 190
Altijd: 122,338
