Ga door naar hoofdinhoud
How to Hack Epson L200's Waste Ink Pad
Angela Penaherrera
Angela Penaherrera en 2 andere bijdragers
Voor het laatst geüpdatet op June 18, 2024
15 minuten
Eenvoudig
Uitgelichte handleiding
Door de gemeenschap gemaakte handleiding
The Epson L200 and similar ink tank models are great, the ink replacements are very efficient and let you print much more for the money it costs replacing them. The big flaw is the waste ink pad.
The printer has a limited amount of times that it can clean the printer's nozzles and do a power ink flush to clean the printer heads. Once the printer reaches it's limits it's software will block you from printing on any computer. Now this is to protect the waste ink pad from overflowing with waste ink but the printer is designed in a way so that it is very hard to replace it.
First you need a software that is available online from many sites to reset the waste ink pad error counter on your printer, I only found it available for PC from this link: http://appuals.com/step-step-guide-reset...
and after that you can follow this guide and even look for youtube videos on how to do this.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. How to Hack Epson L200's Waste Ink Pad, How to Hack Epson L200's Waste Ink Pad: stap 1, afbeelding 1 van 2 How to Hack Epson L200's Waste Ink Pad, How to Hack Epson L200's Waste Ink Pad: stap 1, afbeelding 2 van 2
    • A wild Epson Printer appears.
    • Turn it around and look for a small door.
  2. How to Hack Epson L200's Waste Ink Pad: stap 2, afbeelding 1 van 2 How to Hack Epson L200's Waste Ink Pad: stap 2, afbeelding 2 van 2
    • Locate the small door on the back and open it.
    • You will find the tube that drains the waste ink to the ink pad.
  3. How to Hack Epson L200's Waste Ink Pad: stap 3, afbeelding 1 van 1
    • As you can see, the pad is full with waste ink and is larger than the small door that gives you access to it, meaning it is not meant to be changed by mortals.
  4. How to Hack Epson L200's Waste Ink Pad: stap 4, afbeelding 1 van 2 How to Hack Epson L200's Waste Ink Pad: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • With a pair of tweezers gently pull the ink tube from the ink container.
    • Be careful not to grab it from the tube so as not to damage it.
  5. How to Hack Epson L200's Waste Ink Pad: stap 5, afbeelding 1 van 3 How to Hack Epson L200's Waste Ink Pad: stap 5, afbeelding 2 van 3 How to Hack Epson L200's Waste Ink Pad: stap 5, afbeelding 3 van 3
    Desoldering Pump
    $3.99
    • With the help of a syringe or anything that can suck liquid, clean the remaining ink from the tube.
    • I also went ahead and cleared the pad from as much ink as I could, it can buy you a bit more life span to the pad if you are in a hurry to print and not have the replacement items for this hack.
    • I did not have a syringe at the time and used a desolder pump, takes way longer though.
  6. How to Hack Epson L200's Waste Ink Pad: stap 6, afbeelding 1 van 2 How to Hack Epson L200's Waste Ink Pad: stap 6, afbeelding 2 van 2
    • Cut a 6" piece of the aquarium tubing and grab a connector.
    • Connect the printer tube to the aquarium tubing you just cut with the connector.
  7. How to Hack Epson L200's Waste Ink Pad: stap 7, afbeelding 1 van 1
    • Put a connector on the end of the aquarium tube and connect it to the top of the bottle. Make sure that there is no chance of spilling or else you will have a big black spot of ink under your printer.
    • I inserted another connector on the top side of the bottle to release any pressure created by the ink coming in and the air in the bottle.
  8. How to Hack Epson L200's Waste Ink Pad: stap 8, afbeelding 1 van 1
    • I placed the bottle in a lower elevation than the printer so that the ink can travel down the tube easier.
    • Check periodically to empty the waste ink bottle.
Conclusie
17 andere personen hebben deze handleiding voltooid.
Angela Penaherrera
12.604 Reputatie
5 handleidingen geschreven
13 opmerkingen
I have the same problem. I will try that step. Good instructions. Thank you.
Adi Priyono - Antwoord
Thanks for this! =) God bless!
CHRISTOPHER L. BIRUNG - Antwoord
i need the ressetter for an epson l310
thandolwenkosim - Antwoord
will this work on L220?
Andi Lesmana - Antwoord
anyone have try this?
eufrasiaaa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 103
Altijd: 55,613
