Honeywell HY-204 Fan Blades Replacement
Inleiding
Ga naar stap 1After removing the outer casing, replacing the fan blades is quick and easy! You would want to use this guide to replace the broken part or clean dirty blades.
Wat je nodig hebt
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
