Hamilton Beach 62683 Disassembly
Inleiding
Ga naar stap 1This is a guide on how to take apart the Hamilton Beach Hand Mixer (Model number 62683). This will allow you to take a look inside in case you believe anything is broken or is in need of repair.
Wat je nodig hebt
Gereedschap
Hold the hand-mixer upside down in order to access the bottom.
Remove the three screws using a Phillips #00 screwdriver.
Carefully remove the bottom of the plastic casing.
