Ga door naar hoofdinhoud
Haiboxing 18859 Receiver Replacement
Wat je nodig hebt
  1. Haiboxing 18859 Receiver Replacement, Battery: stap 1, afbeelding 1 van 3 Haiboxing 18859 Receiver Replacement, Battery: stap 1, afbeelding 2 van 3 Haiboxing 18859 Receiver Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the 4 clips holding down the hard plastic shell of the RC car. Do this by pinching them with your thumb and index finger and pulling away.
    Vraag FixBot
    Voeg opmerking toe
  2. Haiboxing 18859 Receiver Replacement: stap 2, afbeelding 1 van 1
    • Lift the hard plastic shell off of the RC car.
    Vraag FixBot
    Voeg opmerking toe
  3. Haiboxing 18859 Receiver Replacement: stap 3, afbeelding 1 van 3 Haiboxing 18859 Receiver Replacement: stap 3, afbeelding 2 van 3 Haiboxing 18859 Receiver Replacement: stap 3, afbeelding 3 van 3
    • Disconnect the Lego-style battery connector by gripping either side and pulling them away from each other, slowly and consistently.
    Vraag FixBot
    Voeg opmerking toe
  4. Haiboxing 18859 Receiver Replacement: stap 4, afbeelding 1 van 3 Haiboxing 18859 Receiver Replacement: stap 4, afbeelding 2 van 3 Haiboxing 18859 Receiver Replacement: stap 4, afbeelding 3 van 3
    • Unfasten the Velcro strap that secures the battery.
    Vraag FixBot
    Voeg opmerking toe
  5. Haiboxing 18859 Receiver Replacement: stap 5, afbeelding 1 van 2 Haiboxing 18859 Receiver Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  6. Haiboxing 18859 Receiver Replacement, Receiver: stap 6, afbeelding 1 van 3 Haiboxing 18859 Receiver Replacement, Receiver: stap 6, afbeelding 2 van 3 Haiboxing 18859 Receiver Replacement, Receiver: stap 6, afbeelding 3 van 3
    • Disonnect all connectors attached to the red, plastic receiver.
    Vraag FixBot
    Voeg opmerking toe
  7. Haiboxing 18859 Receiver Replacement: stap 7, afbeelding 1 van 1
    • Remove the 8 mm Phillips #0 screw holding the front corner of the receiver down.
    • Remove the front corner piece.
    Vraag FixBot
    Voeg opmerking toe
  8. Haiboxing 18859 Receiver Replacement: stap 8, afbeelding 1 van 3 Haiboxing 18859 Receiver Replacement: stap 8, afbeelding 2 van 3 Haiboxing 18859 Receiver Replacement: stap 8, afbeelding 3 van 3
    • Remove the receiver.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kevin Hillmann
258 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 6-3, Botvin Spring 2025 Lid van UMass Dartmouth, Team 6-3, Botvin Spring 2025
UMASSD-BOTVIN-S25S6G3
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 40
Altijd: 577
