Ga door naar hoofdinhoud
HP ProBook 640 G2 Battery Replacement
Wat je nodig hebt
    1. HP ProBook 640 G2 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Flip the laptop so the bottom is facing up.
      • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
      • Use a Torx T9 screwdriver to remove the single 6 mm screw.
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 640 G2 Battery Replacement: stap 2, afbeelding 1 van 1
      • Use a plastic opening tool to carefully pry the bottom case.
      • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
      • Remove the bottom cover.
      Vraag FixBot
      Voeg opmerking toe
    3. HP ProBook 640 G2 Battery Replacement: stap 3, afbeelding 1 van 3 HP ProBook 640 G2 Battery Replacement: stap 3, afbeelding 2 van 3 HP ProBook 640 G2 Battery Replacement: stap 3, afbeelding 3 van 3
      • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
      • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Note - Be sure to dispose of your old battery responsibly! Check out iFixit's Guide on Recycling E-waste.
For optimal performance, calibrate your newly installed battery after completing this guide.
SarahTrachsel
196 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 52
Altijd: 370
