Ga door naar hoofdinhoud
HP ProBook 455 G7 Fan Replacement
Wat je nodig hebt
    1. HP ProBook 455 G7 Fan Replacement, Lower Case: stap 1, afbeelding 1 van 1
      • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
      • Flip the laptop over so the lower case is facing up.
      • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 455 G7 Fan Replacement: stap 2, afbeelding 1 van 3 HP ProBook 455 G7 Fan Replacement: stap 2, afbeelding 2 van 3 HP ProBook 455 G7 Fan Replacement: stap 2, afbeelding 3 van 3
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Lift and remove the lower case.
      Vraag FixBot
      Voeg opmerking toe
    1. HP ProBook 455 G7 Fan Replacement, Battery: stap 3, afbeelding 1 van 3 HP ProBook 455 G7 Fan Replacement, Battery: stap 3, afbeelding 2 van 3 HP ProBook 455 G7 Fan Replacement, Battery: stap 3, afbeelding 3 van 3
      • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
      • Carefully lift the battery and remove it from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. HP ProBook 455 G7 Fan Replacement, Fan: stap 4, afbeelding 1 van 2 HP ProBook 455 G7 Fan Replacement, Fan: stap 4, afbeelding 2 van 2
      • Remove the three 4 mm-long Phillips #1 screws securing the fan.
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 455 G7 Fan Replacement: stap 5, afbeelding 1 van 2 HP ProBook 455 G7 Fan Replacement: stap 5, afbeelding 2 van 2
      • Gently unplug the fan power cable from the motherboard connector using tweezers or your fingers.
      • Lift the fan up and out to remove it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Abeer Zaheer
427 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-6, Botvin Fall 2025 Lid van UMass Dartmouth, Team 1-6, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G6
3 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 33
Altijd: 162
