Inleiding
Does the touchpad of your HP ProBook 440 G6 need inspection or replacing? This guide will demonstrate how to safely replace your laptop's touchpad step-by-step.
The touchpad is an essential part of your device as it provides you the ability to control the cursor. It also provides with clicking, scrolling, and gesture capabilities. It removes any need for an external mouse.
Common Symptoms that may arise due to a faulty touchpad may include:
- Touchpad does not register any gestures
- The cursor does not move, moves on its own, or is very sensitive
- Touchpad does not register left or right clicks
- Ghost touching
This guide will walk you through each step to ensure a smooth and safe replacement of your touchpad. Before beginning this replacement, be sure to completely power off your laptop, unplug it from the charger, and put it in Battery safe Mode.
Wat je nodig hebt
Using a Phillips #0 Screwdriver, remove the two 5 mm screws on the front-facing side of the lower case.
Using a Phillips #0 Screwdriver, remove the remaining five 5 mm Phillips screws securing the lower case.
Starting under the display, carefully use a plastic prying tool (iFixit opening tool) to disengage the retaining clips.
Once a corner or edge starts to lift, slowly slide the tool along the edge to loosen more of the bottom panel.
Keep working around the edges until all the clips are loose.
Using a Phillips #0 Screwdriver, remove the two 4mm Phillips screws that secure the battery to the computer.
Use tweezers to carefully lift and disconnect the silver tape from the touchpad.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
