HP Pavilion dv6-1245dx Battery Replacement
Inleiding
Ga naar stap 1If you need to replace your HP Laptop (HP Pavilion dv6-1245dx) battery, use this guide.
The battery supplies power to the device, enabling it to work without a power cord. The laptop will either be drained of power faster or won’t power on with a faulty battery. Eventually, laptop batteries will rapidly drain after going through a repeated amount of charge cycles. If the battery drains faster than usual, you should replace your battery.
A punctured battery can cause a dangerous fire. If your battery is swollen, take appropriate precautions.
Before using this guide, make sure to turn off any external source of power connected to your device.
Één andere persoon heeft deze handleiding voltooid.
