Ga door naar hoofdinhoud
HP Pavilion 15-au123cl CD Drive Replacement
Mohammad Gardezi
Mohammad Gardezi en een andere bijdrager
Voor het laatst geüpdatet op December 28, 2017
15 - 20 minuten
Gemiddeld
By following this guide, you will be able to replace the CD Drive. The drive is probably the easiest part to replace on the laptop.
Wat je nodig hebt
Gereedschap
  1. HP Pavilion 15-au123cl CD Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CD Drive Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-au123cl CD Drive Replacement: stap 2, afbeelding 2 van 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CD Drive Replacement: stap 3, afbeelding 1 van 2 HP Pavilion 15-au123cl CD Drive Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CD Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion 15-au123cl CD Drive Replacement: stap 4, afbeelding 2 van 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CD Drive Replacement: stap 5, afbeelding 1 van 3 HP Pavilion 15-au123cl CD Drive Replacement: stap 5, afbeelding 2 van 3 HP Pavilion 15-au123cl CD Drive Replacement: stap 5, afbeelding 3 van 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CD Drive Replacement, CD Drive: stap 6, afbeelding 1 van 1
    • The CD Drive is located at the bottom right area of the motherboard.
  7. HP Pavilion 15-au123cl CD Drive Replacement: stap 7, afbeelding 1 van 2 HP Pavilion 15-au123cl CD Drive Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the CD drive from the motherboard connector on the left.
Conclusie
Mohammad Gardezi
1.420 Reputatie
6 handleidingen geschreven
USF Tampa, Team S13-G3, Cagle Fall 2017 Lid van USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 29
Altijd: 642
