HP Pavilion 15-ab165us Battery and Back Cover Replacement
Inleiding
Ga naar stap 1Most components that need to be replaced are inside the base of the laptop. The computer will need to be disassembled in order to reach the inner components. You will remove the battery before delving into the innards of your computer. If you just came here for a battery guide, simply follow to step two and then reassemble!
Wat je nodig hebt
Flip the computer over so that the bottom cover is facing you.
Slide the two locks to the "unlock" position and remove the battery.
10 andere personen hebben deze handleiding voltooid.
Één opmerking
Where can i buy the case? I couldn’t anywhere online??
Model - HP Pavilion 15 8th gen B&O
