Ga door naar hoofdinhoud
HP Pavilion 14-bk061st WLAN Card Replacement
Stefano Lo Re
Stefano Lo Re en 2 andere bijdragers
Voor het laatst geüpdatet op June 23, 2020
1 - 2 minuten
Eenvoudig
Use this guide to replace the WLAN card in your HP Pavilion 14-bk061st laptop.
The WLAN card is a computer component that allows the device to connect to the internet through a wireless signal. In this computer, the WLAN card also handles Bluetooth connections. Bluetooth is another means of wireless communication most often used to connect and transmit information between devices that are in close proximity, usually about 30 feet or less.
Before using this guide, if there is an internet connection issue or Bluetooth connection issue, try using the built-in software diagnostic tools that your computer provides to see what the problem is first.
Remember to power off the computer, and disconnect all external components, including the power adapter, that are plugged into it before starting the repair.
Wat je nodig hebt
Gereedschap
  1. HP Pavilion 14-bk061st WLAN Card Replacement, Back Panel: stap 1, afbeelding 1 van 2 HP Pavilion 14-bk061st WLAN Card Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st WLAN Card Replacement: stap 2, afbeelding 1 van 1
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st WLAN Card Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st WLAN Card Replacement, WLAN Card: stap 4, afbeelding 1 van 2 HP Pavilion 14-bk061st WLAN Card Replacement, WLAN Card: stap 4, afbeelding 2 van 2
    • Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board.
  5. HP Pavilion 14-bk061st WLAN Card Replacement: stap 5, afbeelding 1 van 1
    • Remove the JIS #1 screw from the WLAN card.
  6. HP Pavilion 14-bk061st WLAN Card Replacement: stap 6, afbeelding 1 van 1
    • Remove the card by pulling it away from the slot.
Conclusie
Stefano Lo Re
382 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 687
