HP Pavilion 14-bk061st Screen Replacement
Inleiding
Ga naar stap 1Using this guide will help you in replacing the screen in your HP Pavilion 14-bk061st.
The screen is an important part of all laptops. Some may consider replacing the screen once issues arise during use such as cracked screens after a fall or vertical or horizontal lines sometimes caused by a loose or frayed video cable.
Wat je nodig hebt
Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
Remove the five JIS #1 screws that attach the hinges of the screen to the casing of the laptop.
Één andere persoon heeft deze handleiding voltooid.
