Ga door naar hoofdinhoud
HP Envy x360 m6-aq005dx Power Port Replacement
Bradley Braganza
Bradley Braganza en 3 andere bijdragers
Voor het laatst geüpdatet op January 10, 2019
10 - 15 minuten
Gemiddeld
The power port is essential in recharging the computer's battery. This guide will explain how to properly remove and replace the power port component of the computer.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. HP Envy x360 m6-aq005dx Power Port Replacement, Back Panel: stap 1, afbeelding 1 van 2 HP Envy x360 m6-aq005dx Power Port Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Power Port Replacement: stap 2, afbeelding 1 van 3 HP Envy x360 m6-aq005dx Power Port Replacement: stap 2, afbeelding 2 van 3 HP Envy x360 m6-aq005dx Power Port Replacement: stap 2, afbeelding 3 van 3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Power Port Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Power Port Replacement, Battery: stap 4, afbeelding 1 van 2 HP Envy x360 m6-aq005dx Power Port Replacement, Battery: stap 4, afbeelding 2 van 2
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Power Port Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
  6. HP Envy x360 m6-aq005dx Power Port Replacement, Fan: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to disconnect the power cable from the fan.
  7. HP Envy x360 m6-aq005dx Power Port Replacement: stap 7, afbeelding 1 van 2 HP Envy x360 m6-aq005dx Power Port Replacement: stap 7, afbeelding 2 van 2
    • Use your fingers to lightly pull the cable and disconnect it from the motherboard.
  8. HP Envy x360 m6-aq005dx Power Port Replacement: stap 8, afbeelding 1 van 3 HP Envy x360 m6-aq005dx Power Port Replacement: stap 8, afbeelding 2 van 3 HP Envy x360 m6-aq005dx Power Port Replacement: stap 8, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to loosen the four 6.5 mm screws.
    • Do not fully remove the screws, just enough to be unattached from the motherboard.
    • Use a JIS #1 screwdriver to remove the two 7.7 mm screws.
  9. HP Envy x360 m6-aq005dx Power Port Replacement, Motherboard: stap 9, afbeelding 1 van 2 HP Envy x360 m6-aq005dx Power Port Replacement, Motherboard: stap 9, afbeelding 2 van 2
    • Use a JIS #1 screwdriver to remove the 4.7mm screws from the indicated positions.
    • Use the JIS #1 screwdriver to remove the 7.7mm screws from the indicated positions.
    • Use the JIS #1 screwdriver to remove the 4.4mm screws from the indicated positions.
  10. HP Envy x360 m6-aq005dx Power Port Replacement: stap 10, afbeelding 1 van 1
    • Using your hand, lift the screen hinge located in the top left corner. This will allow for easier removal of the motherboard.
  11. HP Envy x360 m6-aq005dx Power Port Replacement: stap 11, afbeelding 1 van 3 HP Envy x360 m6-aq005dx Power Port Replacement: stap 11, afbeelding 2 van 3 HP Envy x360 m6-aq005dx Power Port Replacement: stap 11, afbeelding 3 van 3
    • Flip the indicated colored latches with iFixit Opening Tools, then use tweezers to release the cables attached to the motherboard by gently pulling backward.
    • Use the pointed tweezer to release the plug-in connectors my gently gripping the plug and pulling backwards.
  12. HP Envy x360 m6-aq005dx Power Port Replacement: stap 12, afbeelding 1 van 3 HP Envy x360 m6-aq005dx Power Port Replacement: stap 12, afbeelding 2 van 3 HP Envy x360 m6-aq005dx Power Port Replacement: stap 12, afbeelding 3 van 3
    • Using your hand, lift and pull the motherboard from inside your computer.
  13. HP Envy x360 m6-aq005dx Power Port Replacement, Power Port: stap 13, afbeelding 1 van 2 HP Envy x360 m6-aq005dx Power Port Replacement, Power Port: stap 13, afbeelding 2 van 2
    • Using your fingers, detach the power port from the motherboard.
Conclusie
Bradley Braganza
235 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G1, Harley Fall 2018 Lid van IUPUI, Team S1-G1, Harley Fall 2018
IUPUI-HARLEY-F18S1G1
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 2,437
