Ga door naar hoofdinhoud
HP Envy m6-k022dx Heatsink Replacement
Kareem Rigaud
Kareem Rigaud en 3 andere bijdragers
Voor het laatst geüpdatet op June 22, 2017
5 minuten
Eenvoudig
You will need the proper size Phillips head screw driver to remove the screws securing the heat sink. You will also need to remove the CPU fan before you start to remove the heat sink.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. HP Envy m6-k022dx Heatsink Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx Heatsink Replacement: stap 2, afbeelding 1 van 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx Heatsink Replacement: stap 3, afbeelding 1 van 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx Heatsink Replacement: stap 4, afbeelding 1 van 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx Heatsink Replacement, CPU Fan: stap 5, afbeelding 1 van 1
    • The fan is located here. You will need to remove three screws in order to lift the fan out from the motherboard.
    • You will need a Phillips 00 size screwdriver to remove the screws.
  6. HP Envy m6-k022dx Heatsink Replacement: stap 6, afbeelding 1 van 1
    • Use your screwdriver to remove the three screws connecting the fan to the motherboard.
  7. HP Envy m6-k022dx Heatsink Replacement: stap 7, afbeelding 1 van 1
    • Grab the fan with your hand, and lift up and away from the motherboard.
  8. HP Envy m6-k022dx Heatsink Replacement: stap 8, afbeelding 1 van 1
    • Grab the fan power connector by the wires and pull directly away from port until the cable is disconnected.
  9. HP Envy m6-k022dx Heatsink Replacement, Heatsink: stap 9, afbeelding 1 van 1
    • Prepare to remove the heatsink by removing the four screws that connect it to the motherboard.
    • Make sure you have a Philips 00 size screwdriver to remove the screws.
  10. HP Envy m6-k022dx Heatsink Replacement: stap 10, afbeelding 1 van 1
    • Unscrew all four of the screws connecting the heat sink to the CPU.
  11. HP Envy m6-k022dx Heatsink Replacement: stap 11, afbeelding 1 van 1
    • Lift up the heat sink by the strip of metal connecting it to the exhaust vent, and pull it away from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kareem Rigaud
403 Reputatie
3 handleidingen geschreven
USF Tampa, Team S13-G6, Cagle Spring 2017 Lid van USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 668
