Ga door naar hoofdinhoud
HP Envy dv7t-7200 Hard Drive Replacement
Krystal
Krystal en 3 andere bijdragers
Voor het laatst geüpdatet op December 29, 2017
7 - 10 minuten
Gemiddeld
Use this guide to replace a faulty hard drive on your HP Envy dv7t-7200 if your laptop is running slowly, begins freezing, or has corrupt files. There are two hard drives within this laptop that can be removed and replaced in a few steps.
Wat je nodig hebt
Gereedschap
  1. HP Envy dv7t-7200 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Hard Drive Replacement: stap 2, afbeelding 1 van 3 HP Envy dv7t-7200 Hard Drive Replacement: stap 2, afbeelding 2 van 3 HP Envy dv7t-7200 Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Hard Drive Replacement, Service Cover: stap 4, afbeelding 1 van 1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Hard Drive Replacement: stap 5, afbeelding 1 van 2 HP Envy dv7t-7200 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
  6. HP Envy dv7t-7200 Hard Drive Replacement, Hard Drive: stap 6, afbeelding 1 van 1
    • Remove the 2 Phillips PM2.5×5.5 top screws from brackets on both hard drives.
  7. HP Envy dv7t-7200 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Remove the primary drive first located on the right hand side.
    • Use the black tab to lift the drive up and out.
  8. HP Envy dv7t-7200 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Remove the 2 Phillips PM2.5×5.5 screws on each side of the drive bracket.
  9. HP Envy dv7t-7200 Hard Drive Replacement: stap 9, afbeelding 1 van 1
    • Remove the hard drive connector cable.
    • This cable can be difficult to remove. Try to pull this cable firmly and carefully.
  10. HP Envy dv7t-7200 Hard Drive Replacement: stap 10, afbeelding 1 van 1
    • Repeat steps 6-9 for the secondary hard drive.
Conclusie
To reassemble your device, follow these instructions in the reverse order.
Één andere persoon heeft deze handleiding voltooid.
Krystal
882 Reputatie
8 handleidingen geschreven
UW Tacoma, Team S3-G3, Liner Fall 2017 Lid van UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 356
