Ga door naar hoofdinhoud
HP Envy 700-030qe Power Supply Replacement
Yoav Rosenberg
Yoav Rosenberg en 2 andere bijdragers
Voor het laatst geüpdatet op December 28, 2017
5 minuten
Eenvoudig
If your are having problems turning on the computer your power supply might be at fault. If you need to replace it you will need to remove the side panel, disconnect and dismount the power supply.
Wat je nodig hebt
Gereedschap
  1. HP Envy 700-030qe Power Supply Replacement, Power Supply: stap 1, afbeelding 1 van 3 HP Envy 700-030qe Power Supply Replacement, Power Supply: stap 1, afbeelding 2 van 3 HP Envy 700-030qe Power Supply Replacement, Power Supply: stap 1, afbeelding 3 van 3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe Power Supply Replacement: stap 2, afbeelding 1 van 2 HP Envy 700-030qe Power Supply Replacement: stap 2, afbeelding 2 van 2
    • Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
  3. HP Envy 700-030qe Power Supply Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 5mm screws holding the power supply in place with a T15 Torx screwdriver.
  4. HP Envy 700-030qe Power Supply Replacement: stap 4, afbeelding 1 van 2 HP Envy 700-030qe Power Supply Replacement: stap 4, afbeelding 2 van 2
    • Undo the clasp which holds the power supply in place by pushing down on it.
    • Pull out the power supply up and towards you.
  5. HP Envy 700-030qe Power Supply Replacement: stap 5, afbeelding 1 van 1
    • Unplug the power cable going to the CD drive by pulling straight.
  6. HP Envy 700-030qe Power Supply Replacement: stap 6, afbeelding 1 van 1
    • Set aside the power supply on the left side of the computer.
  7. HP Envy 700-030qe Power Supply Replacement: stap 7, afbeelding 1 van 1
    • Unplug the SATA interface power cable going to the hard drive by pulling straight up.
  8. HP Envy 700-030qe Power Supply Replacement: stap 8, afbeelding 1 van 1
    • Unplug the power cable going to the mother board by pulling straight up.
  9. HP Envy 700-030qe Power Supply Replacement: stap 9, afbeelding 1 van 1
    • Unplug the power cable going to the fan by pulling straight up.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Yoav Rosenberg
369 Reputatie
2 handleidingen geschreven
Cal Poly, Team 5-9, Maness Fall 2015 Lid van Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 Leden
10 handleidingen geschreven
0 Guide Comments
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 36
Altijd: 4,533
