Ga door naar hoofdinhoud
HP Elitebook Folio 9470m Trackpad Replacement
Kenneth Bowers
Kenneth Bowers en 5 andere bijdragers
Voor het laatst geüpdatet op December 15, 2023
30 minuten
Gemiddeld
Use this guide to replace your HP Elitebook Folio 9470m Trackpad
If your laptop no longer is responsive to movements on the trackpad or does not function properly, your trackpad is likely faulty and may need replacement. There are no special skills involved in the replacement if the trackpad.
Before using this guide, make sure to review the troubleshooting page to ensure that the trackpad doesn't have any driver issues or other issues.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
Wat je nodig hebt
Gereedschap
  1. HP Elitebook Folio 9470m Trackpad Replacement, Trackpad: stap 1, afbeelding 1 van 1
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Trackpad Replacement: stap 2, afbeelding 1 van 1
    • In the center of the laptop slide the black piece back till it turns red indicating it is unlocked and the battery can be removed.
  3. HP Elitebook Folio 9470m Trackpad Replacement: stap 3, afbeelding 1 van 2 HP Elitebook Folio 9470m Trackpad Replacement: stap 3, afbeelding 2 van 2
    • Remove the 2 Phillips head screws that attach the cover on the left.
  4. HP Elitebook Folio 9470m Trackpad Replacement: stap 4, afbeelding 1 van 3 HP Elitebook Folio 9470m Trackpad Replacement: stap 4, afbeelding 2 van 3 HP Elitebook Folio 9470m Trackpad Replacement: stap 4, afbeelding 3 van 3
    • Remove the 4 Phillips screws holding the hard drive in place
    • Remove by gently prying and pulling up on the tab and out.
  5. HP Elitebook Folio 9470m Trackpad Replacement: stap 5, afbeelding 1 van 3 HP Elitebook Folio 9470m Trackpad Replacement: stap 5, afbeelding 2 van 3 HP Elitebook Folio 9470m Trackpad Replacement: stap 5, afbeelding 3 van 3
    • Remove the 3 Phillips head screws holding the back plate in.
    • Gently pull up and out to remove plate.
  6. HP Elitebook Folio 9470m Trackpad Replacement: stap 6, afbeelding 1 van 2 HP Elitebook Folio 9470m Trackpad Replacement: stap 6, afbeelding 2 van 2
    • Remove all eighteen screws marked M2x3 and M2x5.
    • Remove the remaining four Phillips head screws.
  7. HP Elitebook Folio 9470m Trackpad Replacement: stap 7, afbeelding 1 van 2 HP Elitebook Folio 9470m Trackpad Replacement: stap 7, afbeelding 2 van 2
    • Slowly pry and lift the frame up while checking for connected wires and ribbons that may be obstructing it.
  8. HP Elitebook Folio 9470m Trackpad Replacement: stap 8, afbeelding 1 van 2 HP Elitebook Folio 9470m Trackpad Replacement: stap 8, afbeelding 2 van 2
    • Detach ribbon wires by gently lifting the grey flap and pulling them out.
    • Do not pull hard on the wires.
    • Push the track pad from the bottom and it should come right out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kenneth Bowers
1.432 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 Lid van UMass Dartmouth, Team S1-G1, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G1
4 Leden
19 handleidingen geschreven
Één opmerking
Please make sure the Track Pad is not "turned off:" (HP Folio has a Track Pad on/off feature by double-tap in upper left hand corner)
1) Double tap the upper left corner of the Track Pad by the Amber LED
2a) If the LED is "On" then the Track Pad is "Off"
2b) If the LED is "Off" then the Track Pad is "On"
nemisonic - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 36
Altijd: 4,065
