HP Elitebook Folio 9470m Keyboard Replacement
Inleiding
Ga naar stap 1Your keyboard is an important part of your computer, so when it's not working properly and responding the way you're used to, it's only natural that you want to replace it as soon as possible.
On a desktop computer, if the keyboard is completely unresponsive, it will definitely need to be replaced.
However, keyboard problems can physical or digital via drivers. Windows and your keyboard may have a complicated relationship, and if your keyboard has multimedia buttons to adjust the volume or open web pages, you probably have specific software installed called a keyboard driver. If the controller fails, the keyboard will not work properly - but this is not a sign that the keyboard needs to be replaced. Downloading a new keyboard driver from the manufacturer's website will solve most problems. You don't need a new keyboard for this, just new software.
Wat je nodig hebt
Gereedschap
Flip the laptop over and locate the 2 tabs on the left or right sides. They will be slightly visible in the space between the keyboard and frame.
Using a plastic opening tool, push the tabs in while pulling up to disconnect the tabs from the keyboard frame.
Once both tabs become unclipped, lift the keyboard up gently allowing it to slightly bend as the front and back tabs come out.
Één andere persoon heeft deze handleiding voltooid.
