Ga door naar hoofdinhoud
HP Elitebook Folio 9470m Keyboard Replacement
Kenneth Bowers
Kenneth Bowers en 7 andere bijdragers
Voor het laatst geüpdatet op December 15, 2023
20 minuten
Gemiddeld
Your keyboard is an important part of your computer, so when it's not working properly and responding the way you're used to, it's only natural that you want to replace it as soon as possible.
On a desktop computer, if the keyboard is completely unresponsive, it will definitely need to be replaced.
However, keyboard problems can physical or digital via drivers. Windows and your keyboard may have a complicated relationship, and if your keyboard has multimedia buttons to adjust the volume or open web pages, you probably have specific software installed called a keyboard driver. If the controller fails, the keyboard will not work properly - but this is not a sign that the keyboard needs to be replaced. Downloading a new keyboard driver from the manufacturer's website will solve most problems. You don't need a new keyboard for this, just new software.
Wat je nodig hebt
Gereedschap
  1. HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Elitebook Folio 9470m Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Remove battery by pushing slide over to red, lifting slightly up while pulling the battery out.
  3. HP Elitebook Folio 9470m Keyboard Replacement: stap 3, afbeelding 1 van 3 HP Elitebook Folio 9470m Keyboard Replacement: stap 3, afbeelding 2 van 3 HP Elitebook Folio 9470m Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Remove hard drive cover plate by unscrewing the 2 Phillips head screws and lifting slightly up and out.
  4. HP Elitebook Folio 9470m Keyboard Replacement: stap 4, afbeelding 1 van 3 HP Elitebook Folio 9470m Keyboard Replacement: stap 4, afbeelding 2 van 3 HP Elitebook Folio 9470m Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Remove back cover by unscrewing the 3 Phillips head screws, then lift the plate up and out.
  5. HP Elitebook Folio 9470m Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the 4 Phillips head keyboard screws.
    • The screws are also marked with small keyboard icons to distinguish them.
  6. HP Elitebook Folio 9470m Keyboard Replacement: stap 6, afbeelding 1 van 3 HP Elitebook Folio 9470m Keyboard Replacement: stap 6, afbeelding 2 van 3 HP Elitebook Folio 9470m Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Flip the laptop over and locate the 2 tabs on the left or right sides. They will be slightly visible in the space between the keyboard and frame.
    • Using a plastic opening tool, push the tabs in while pulling up to disconnect the tabs from the keyboard frame.
    • Once both tabs become unclipped, lift the keyboard up gently allowing it to slightly bend as the front and back tabs come out.
  7. HP Elitebook Folio 9470m Keyboard Replacement: stap 7, afbeelding 1 van 2 HP Elitebook Folio 9470m Keyboard Replacement: stap 7, afbeelding 2 van 2
    • While lifting the keyboard up only enough to see underneath, unclip and remove the ribbon wire to fully detach the keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kenneth Bowers
1.432 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 Lid van UMass Dartmouth, Team S1-G1, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G1
4 Leden
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 58
Altijd: 5,781
