Ga door naar hoofdinhoud
HP EliteBook x360 1030 G3 WWAN Card Replacement
Shea Charkowsky
Shea Charkowsky en 5 andere bijdragers
Voor het laatst geüpdatet op August 28, 2024
6 minuten
Eenvoudig
Follow this guide to replace the WWAN card in your HP EliteBook x360 1030 G3 laptop.
The WWAN (Wireless Wide Area Network) card allows you to connect to the internet using a cellular connection. If your computer has a WWAN card installed and you're having trouble using cellular, you may have a faulty WWAN card.
If you are having trouble accessing a local Wi-Fi or Bluetooth connection, you may have an issue with your WLAN card, which cannot be replaced independently of the motherboard on this laptop.
Wat je nodig hebt
Gereedschap
  1. HP EliteBook x360 1030 G3 WWAN Card Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 WWAN Card Replacement: stap 2, afbeelding 1 van 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 WWAN Card Replacement, WWAN Card: stap 3, afbeelding 1 van 2 HP EliteBook x360 1030 G3 WWAN Card Replacement, WWAN Card: stap 3, afbeelding 2 van 2
    • Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
    • These wires should be handled carefully since they're the mobile cell service/WWAN antennas.
    • Take note of which wire goes where, as mixing these cables will cause the mobile cell service/WWAN to stop working.
  4. HP EliteBook x360 1030 G3 WWAN Card Replacement: stap 4, afbeelding 1 van 1
    • Remove the 2.4 mm screw holding the card down using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 WWAN Card Replacement: stap 5, afbeelding 1 van 2 HP EliteBook x360 1030 G3 WWAN Card Replacement: stap 5, afbeelding 2 van 2
    • Carefully pull out the card by sliding it to the left.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Shea Charkowsky
816 Reputatie
3 handleidingen geschreven
Cal Poly, Team S2-G9, Maness Spring 2019 Lid van Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 38
Altijd: 2,723
