Ga door naar hoofdinhoud
HP Compaq nc6400 Optical Drive Replacement
Chad Williams
Chad Williams en 7 andere bijdragers
Voor het laatst geüpdatet op January 3, 2024
15 - 30 minuten
Gemiddeld
This guide will take you through the process of replacing the optical drive in a HP Compaq nc6400 Laptop. You will need the correct replacement optical drive for your laptop to complete the installation.
Wat je nodig hebt
Gereedschap
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. HP Compaq nc6400 Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Optical Drive Replacement: stap 3, afbeelding 1 van 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Optical Drive Replacement: stap 4, afbeelding 1 van 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Optical Drive Replacement, Optical Drive: stap 5, afbeelding 1 van 2 HP Compaq nc6400 Optical Drive Replacement, Optical Drive: stap 5, afbeelding 2 van 2
    • Remove the 4 mm P0 Phillips-head screw indicated by the icon of a lock and disk.
  6. HP Compaq nc6400 Optical Drive Replacement: stap 6, afbeelding 1 van 2 HP Compaq nc6400 Optical Drive Replacement: stap 6, afbeelding 2 van 2
    • Press and release the eject icon to partially eject the optical drive.
    • Use of a spudger may be necessary to pry open the optical drive.
  7. HP Compaq nc6400 Optical Drive Replacement: stap 7, afbeelding 1 van 1
    • Grasp the sides and pull the optical drive out.
Conclusie
Chad Williams
252 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-6, Forte Fall 2013 Lid van Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 15
Altijd: 4,673
