HP Chromebook 11 G8 EE Screen Replacement
45 minuten
Gemiddeld
Inleiding
Ga naar stap 1For this guide, you will be replacing the screen on your HP Chromebook 11 G8 EE. You may need to replace the screen if it is cracked or no longer functional. It's important your device is fully powered down throughout this process.
Wat je nodig hebt
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Bijna klaar!
Conclusie
