Ga door naar hoofdinhoud
Google Pixel Display Replacement
Wat je nodig hebt
  1. Google Pixel Display Replacement, Display: stap 1, afbeelding 1 van 1
    • Turn off the device.
    • Prepare an iOpener to heat the edges of the display and soften the adhesive underneath. Alternatively, you may use a heat gun or a hair dryer.
    • The surfaces near the speaker and microphone (top and bottom respectively) have larger adhesive sections. These areas may require slightly longer heat exposure. The display should be heated until it's slightly too hot to touch, for roughly two minutes.
    Vraag FixBot
    Voeg opmerking toe
  2. Google Pixel Display Replacement: stap 2, afbeelding 1 van 3 Google Pixel Display Replacement: stap 2, afbeelding 2 van 3 Google Pixel Display Replacement: stap 2, afbeelding 3 van 3
    • In the following steps, you will separate the display panel by slicing though the adhesive bonding the display to the Pixel's chassis.
    • For reference, the back of the display panel is shown at left. Note the narrow clearance between the side of the display unit and the OLED panel. (The bezels indicate this spacing on the front.)
    • Inserting an opening tool deeper than 1.5 mm into the sides of the device, or 9 mm into the top and bottom can permanently damage the display.
    Vraag FixBot
    Voeg opmerking toe
  3. Google Pixel Display Replacement: stap 3, afbeelding 1 van 2 Google Pixel Display Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Suction Handle
    $2.95
    • Use a suction handle to pull up on the display and create a slight gap between the display and the phone's chassis.
    • If your display is cracked, cover it with packing tape to help the suction cup adhere and prevent glass shards from popping loose.
    • You may need to apply more heat if this doesn't come up. Don't be impatient, this will take time. Once you can gently insert a tool in the gap, move on to the next step.
    Vraag FixBot
    Voeg opmerking toe
  4. Google Pixel Display Replacement: stap 4, afbeelding 1 van 3 Google Pixel Display Replacement: stap 4, afbeelding 2 van 3 Google Pixel Display Replacement: stap 4, afbeelding 3 van 3
    • Insert an opening pick or a playing card into the gap between the chassis and the display assembly.
    • Begin to slide the opening pick around the edge of the display, cutting through the adhesive that secures it.
    • Do not try to lift or pry the screen off with the pick. Simply slide it around to detach the adhesive.
    • The display panel is extremely fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
    Vraag FixBot
    Voeg opmerking toe
  5. Google Pixel Display Replacement: stap 5, afbeelding 1 van 3 Google Pixel Display Replacement: stap 5, afbeelding 2 van 3 Google Pixel Display Replacement: stap 5, afbeelding 3 van 3
    • Continue carefully separating the adhesive around the rest of the device.
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    • Take extra care with the side bezels, which are only 1.5 mm deep.
    Vraag FixBot
    Voeg opmerking toe
  6. Google Pixel Display Replacement: stap 6, afbeelding 1 van 3 Google Pixel Display Replacement: stap 6, afbeelding 2 van 3 Google Pixel Display Replacement: stap 6, afbeelding 3 van 3
    iFixit Opening Picks (Set of 6)
    $4.95
    • With the adhesive cut, slowly lift the display up from the top (the side with the speaker-grille cutout), carefully flip it over vertically toward the bottom of the device, and rest it on its face, as shown.
    • Don't forget there's sticky adhesive everywhere, so consider resting an opening pick between the screen and display, to avoid spreading the gunk!
    • Do not attempt to completely remove the display yet, as it is still connected by a fragile ribbon cable. Be careful to not to strain the cable while positioning the display.
    Vraag FixBot
    Voeg opmerking toe
  7. Google Pixel Display Replacement: stap 7, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    • Use a T5 Torx driver to remove the two black 3.5 mm T5 screws securing the display cable connector bracket.
    Vraag FixBot
    Voeg opmerking toe
  8. Google Pixel Display Replacement: stap 8, afbeelding 1 van 1
    • Use tweezers to remove the bracket that holds the display connector in place.
    • This is just a piece of metal, and should come up very easily. (The cable is removed in the next step.)
    Vraag FixBot
    Voeg opmerking toe
  9. Google Pixel Display Replacement: stap 9, afbeelding 1 van 1
    • Use a spudger to pry up the display cable connector, freeing the display.
    • On reassembly, gently snap one side in, then the other.
    • Do not force this type of connector into place, as damage can occur. (You will need to feel a light snap, but force beyond this will permanently damage your connector.)
    Vraag FixBot
    Voeg opmerking toe
  10. Google Pixel Display Replacement: stap 10, afbeelding 1 van 1
    • Remove the display.
    • Some replacement displays do not come with an earpiece speaker grille. If your replacement screen doesn't have one, be sure to transfer the grille from your old display to the new one.
    • During reassembly, pause here to test the functionality of your new part and replace the display adhesive.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
59 andere personen hebben deze handleiding voltooid.
Taylor Dixon
72.588 Reputatie
94 handleidingen geschreven
19Gids Commentaar
hey, is the replacement screen meant to have adhesive on it already?
noisycrow - Antwoord Deel
No, it does not. Just replaced my screen. The residual adhesive is good enough to keep it on temporarily, but I’m going to a local repair shop to grab something better.
Vitaliy Isikov - Antwoord Deel
It’s also best to, if you haven’t already, look at your replacement part to get a feeling of how far you can go with the guitar pick or pry tool. It’s around 1/16th of an inch on the sides so you don’t want to go too far in and damage the display
Jason Stewart - Antwoord Deel
Honestly, this felt easier than what the guide advised, definitely invest in the ifixit opening kit, made this a breeze. Hardest part was just scrapping the leftover residue off after removing the cracked screen.
Craig Beery II - Antwoord Deel
You can use any adhesive for screen replacements for this screen. I personally used a double-sided tape 2 mm wide. The replacement screen does not usually come with the fabric covering the phone speakers, so make sure to transfer it from your old screen.
Mingye Wang - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 94
Afgelopen 30 dagen: 298
Altijd: 110,618
