Inleiding
Follow this guide to remove or replace the battery in your GameSir Cyclone 2 controller.
Wat je nodig hebt
Flip the controller around so the back part is facing you.
Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
Pull both joystick covers straight up to remove them from the controller.
Locate the two black boxes towards the bottom of the controller.
Remove these two boxes by pulling them away from the controller. They should snap right off.
Use a Phillips #00 screwdriver to remove the four screws that secure the LED diffuser tracks.
Remove the LED diffuser tracks.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Één andere persoon heeft deze handleiding voltooid.
2Gids Commentaar
Which battery is used there. I mean the specs so I can buy it.
Hi @daviribeiro, we don't have the specific battery details, but it uses a 860mAh rechargeable Lithium-ion battery.
