Ga door naar hoofdinhoud
Game Boy Screen Replacement
Wat je nodig hebt
  1. Game Boy Screen Replacement, Batteries: stap 1, afbeelding 1 van 2 Game Boy Screen Replacement, Batteries: stap 1, afbeelding 2 van 2
    • Switch your Game Boy off and remove the cartridge.
    Vraag FixBot
    Voeg opmerking toe
  2. Game Boy Screen Replacement: stap 2, afbeelding 1 van 3 Game Boy Screen Replacement: stap 2, afbeelding 2 van 3 Game Boy Screen Replacement: stap 2, afbeelding 3 van 3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
    Vraag FixBot
    Voeg opmerking toe
  3. Game Boy Screen Replacement: stap 3, afbeelding 1 van 2 Game Boy Screen Replacement: stap 3, afbeelding 2 van 2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
    Vraag FixBot
    Voeg opmerking toe
  4. Game Boy Screen Replacement, Outer Case: stap 4, afbeelding 1 van 1
    • Remove the six Triwing screws from the back of the device.
    Vraag FixBot
    Voeg opmerking toe
  5. Game Boy Screen Replacement: stap 5, afbeelding 1 van 1
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
    Vraag FixBot
    Voeg opmerking toe
  6. Game Boy Screen Replacement: stap 6, afbeelding 1 van 1
    • Slide the front side of the casing down to expose the ribbon cable connector.
    Vraag FixBot
    Voeg opmerking toe
  7. Game Boy Screen Replacement: stap 7, afbeelding 1 van 1
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
    Vraag FixBot
    Voeg opmerking toe
  8. Game Boy Screen Replacement, Screen: stap 8, afbeelding 1 van 1
    • Remove the ten screws that connect the circuit board to the outer case.
    Vraag FixBot
    Voeg opmerking toe
  9. Game Boy Screen Replacement: stap 9, afbeelding 1 van 2 Game Boy Screen Replacement: stap 9, afbeelding 2 van 2
    • Remove the circuit board from the outer case using a plastic opening tool.
    • Take care to gently pry around the entire outside edge of the circuit board until you can easily remove the board without force.
    Vraag FixBot
    Voeg opmerking toe
  10. Game Boy Screen Replacement: stap 10, afbeelding 1 van 1
    • Disengage the the three plastic clips that secure the screen to the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  11. Game Boy Screen Replacement: stap 11, afbeelding 1 van 3 Game Boy Screen Replacement: stap 11, afbeelding 2 van 3 Game Boy Screen Replacement: stap 11, afbeelding 3 van 3
    • Flip the circuit board over revealing the device screen.
    • Remove the two screws connecting the screen and the circuit board.
    Vraag FixBot
    Voeg opmerking toe
    • Follow the video instructions to desolder the display connectors and replace your screen.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
50 andere personen hebben deze handleiding voltooid.
Andrew Tramposch
2.378 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-2, Johann Summer 2010 Lid van Cal Poly, Team 3-2, Johann Summer 2010
CPSU-JOHANN-R10S3G2
3 Leden
40 handleidingen geschreven
14Gids Commentaar
What kind of lcd screen or where can I find one that isn't off of another dmg-01 gameboy?
Floyd Odom - Antwoord Deel
I was wondering the same. Maybe ebay or Amazon.
Joshua Graham - Antwoord Deel
Replacement reflective LCDs are not possible to find. You can either purchase a screen salvaged from an old DMG, or get a brand new backlit LCD replacement.
mars - Antwoord Deel
What about the new display? Where to get it?
No spare part necessary should be replaced with a link where to buy a new one.
Helmut Kohli - Antwoord Deel
You can’t buy a new replacement screen unfortunately. Not only is it very difficult to remove the screen, it’s impossible to buy a replacement. They’d be better showing us how to fix a screen. There’s plenty of videos on YT showing how to fix blank vertical line but hardly any on how to fix horizontal lines, and the ones that do don’t work very well.
Firegoose - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 35
Afgelopen 7 dagen: 323
Afgelopen 30 dagen: 1,500
Altijd: 178,867
